No monitor display
When I switch on my desktop pc nothing appears on the monitor but the cpu fan runs. The red light stays stationary red. No light on the floppy drive but there is light on the cd rom drive. I suspect cpu problem. What do you think? This was after changing something in the bios.
Babington
  • bbrw Apr 21, 2008
    A cd in DVD drive D is read upon rebooting, but when the cd is removed and another one is inserted, windows cannot see/read the cd. Instead info of the previous cd remains stuck there until I reboot again. Even if the previous cd is now inserted, it cannot be read until after reboot.
    How can I correct this problem?
  • 4,102 Answers
Hi could you please check all leads are in back of computer if these are ok then take the case of and check the leads going to the hard drive as this can give you this problem maybe one of the rwo leads going to the hd hve come loose check this then get back to me ok
If you can hear the cd drive work then put windows disk in and see if it loads from disk if not then check the leads to the hard drive ok then get back to me
Posted on Apr 23, 2008
  • paul proctor Apr 23, 2008
    It sounds like hard drive problem or it could even be that the ram is in wrong slots like p133 in p100 slot and visa versa this can cause the problem your having so if you have moved these then try swaping them round ok but double check you can hear the hard drive boot up you should hear it the same as cd drive
  • 13,433 Answers
This is a bit confuseing, so your pc is working or not? do you get image on the screen?
  • Ekse Apr 23, 2008
    do you hear any beeps?
Will not boot,,,nothing appears on monitor
Does it have any power at all? Do any lights come on? Does the fan come on for the power supply or the CPU? Any beeps heard? Did it run properly before or is it a new build?
Please provide more details.
Jan 23, 2011 | HP Compaq Presario SR1211NX (829160534404)...
I was given an emachine T2742, I turned it on and it worked for a little while and then went off by itself. I can hear and see the fan running. It will not come on but will continue to try to start. ...
After running can you feel any heat around the CPU heatsink? Does the CPU fan run at all?
Is it trying to restart and then looping back to reboot?
Try to access the Bios (press Del as soon as it switches on) see if you can get to the bios screen, see how long it will stay in the Bios screen before switching off or rebooting. If the bios has a hardware monitor, see what the temp of the CPU is. 30 degrees to 40 degrees is normal
Then switch off, unplug the Optical drives, the hard drive and floppy drive in turn, try to reboot and see if it is stable with just the hard drive installed.
IF the CPU heatsink remains cool after all that, the issue is with a dead CPU or a blown component on the motherbiard
Dec 29, 2010 | E-Machines T2742 PC Desktop
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Changed the CPU fan and now the monitor won't turn on. Power light stays green, and harddrive light stays yellow. Fan is running.
its not problem of fan. re-insert your ram. even if doesnt come then problem with ur motherboard chipset. if in blore call 9972888885
Jan 21, 2010 | Compaq Presario S6000CL (DT072A) PC...
Philips LX1000 not booting up
I need many more information
1) is their a power on the CPU. if yes lets check the monitor, uplug the monitor and turn only the monitor on, their should be some message on the monitor. If no error message on the monitor, possible monitor issue.
2) do you find any error message on the screen
2) If no light on the tower, do you find any light on the back.. please reply to this question
Dec 15, 2009 | Computers & Internet
Have a t6532 running fine one moning blue light blinking no boot fan runs 3 seconds no noise then blue light blinks nothing runs.
UNPLUG all keyboard, mose and etc and plug only power suppl and then video cable with the cpu and then power on you can get the display in you monitor
Oct 20, 2009 | E-Machines eMachines Desktop PC
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
