Toshiba Satellite A205-S4617 15.4" Notebook PC (Intel Core 2 Duo Processor T5500, 2 GB RAM, 250 GB H... PC Notebook
Problem for Toshiba Satellite A205-S4617 15.4" Notebook PC (Intel Core...
A friend's laptop won't turn on - no power even
By xiannatogo on Nov 11, 2009
a friend's laptop won't turn on - no power even with using the adaptor
Solution #1
posted on Nov 11, 2009
Not Rated)
Soulvisitor
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 2355 votes
battery dead, end of its life, , if it is dead it sometime also stops it working with the adaptor, remove battery and try with adaptor, if it works you need a new battery, if it doesn't then it is likely the adaptor itself , make sure you have checked the lead and tested the power point, as a teco I would get my multi meter to test for power out of adaptor to ensure it was only that not something more drastic like the main board of the lappy...cheers
Was this helpful?
Yes
No
Solution #2
Not Rated)
nanbuenbrazo
Rank: Wiz  Computer Hardware  Expert
Rating: 78%, 167 votes
Other model of laptop does'nt power on even though it is connected to a power supply in case the battery is dead, others can be run even only the adaptor and without battery.
Try to check the battery first.
Was this helpful?
Yes
No
Solution #3
Not Rated)
leethedeuce
Rating: 86%, 491 votes
then the laptop is in need of repair. It may need a new power supply or whole main board. If it still under warranty have it serviced. otherwise you will be responsible for parts and labor.
Thank you,
Lee
Was this helpful?
Yes
No
Solution #4
Not Rated)
jennifer720
Rating: 88%, 162 votes
Hello and thank you for using Fixya's services.
I have a couple of questions and some troubleshooting tips for you:
Questions: Is the splash screen coming on at all? Any picture or text right when you boot up? What Windows are you running (Windows XP or Vista)? Are there any lights on when you boot up or beeps? If so how many beeps do you hear?
First troubleshooting: If it boots up and is at least showing the splash screen (Toshiba splash screen or text) then it would be that the operating system is corrupt. This can be caused by several things included viruses, power surges or hardware failure.
The solution for this would be to take the hard drive out and slave it to another working desktop computer to retrieve your data. The attach the hard drive back on and reformat it (I can add specifics to doing this once I know the operating system).
Second troubleshooting: If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website and pull specs for free.
Third troubleshooting: If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Fourth troubleshooting: To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
Please let me know if you have any questions and I will be glad to assist.
Was this helpful?
Yes
No
Solution #5
Not Rated)
milleraba
Rating: 83%, 462 votes
dead power supply - dead battery - dead wall out let ... dead laptop. The answer is in here somewhere.
Was this helpful?
Yes
No
Solution #6
Not Rated)
mulmol
Rating: 79%, 95 votes
Have the adapter checked by a certified technician.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A205-S4617
Questions and Unsolved Problems for Toshiba Satellite A205-S4617
Do you recommend Toshiba Satellite A205-S4617 15.4" Notebook PC (Intel Core 2 Duo Processor T5500, 2 GB RAM, 250 GB H... PC Notebook?
Answer
Answer
toshiba a205-s4617 won't connect to wireless router, it sees the router but will not connect
Answer
Assunto: Apoio Técnico Computador, Toshiba Mod. S P300-19F Ref: PSPCCE-00N021PT N... (More)
Answer
there is no sound comeing from the speakers, and at the bottem right hand side the sound pic.... (More)
Answer
I have a CD/DVD burner in my laptop. After installing my iPod, I noticed that I can no longer play... (More)
Answer
i looked for the codes in wildtangentorb.com and i follow the steps how to purchase it and i did but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A205-S4617...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
