Question about Sunbeam SCA103RWB1 Room Air Conditioner
Turn on and off the unit
Sincerely,
Change yesterday fourth-air cooling and it turns out very well and works but every 10 minutes off the unit and turn every 3 minutes which is not normal.
Not to be this change?
Just pass it to another quarter, I am somewhat inclined to back. Sera that the problem?
Thanks
  • 236 Answers
-Check the setting of your temperature.
-Check if the timer is not set.
-Check if no restriction in your outdoor or indoor and outdoor are both clean.
-Check if no error code (flashing light) at the indoor.
Posted on Jan 07, 2008
Belt off of pro form 700 cardio cross trainer
Dear Sir: Hello , I hope everything is fine.
Please do the following: o 1 Remove the key from the machine and unplug the unit for safety purposes. o 2 Adjust the rear roller adjustment bolts using an allen wrench. The right bolt should be turned one-fourth turn clockwise and the left bolt should be turned one-fourth turn counterclockwise. o 3 Place the key back into the unit and plug it back into its power source. o 4 Run the Proform treadmill for five minutes to make sure that the walking belt has fully recentered itself. o 5 Repeat these steps if necessary.
If the Belt Slip when in use: o 1 Unplug the unit and remove the key card. o 2 Tighten the walking belt by turning both rear adjustment bolts clockwise using an Allen wrench. o 3 Replug the unit and reinsert the key card.
Thank you in advance, sincerely. Blessing.
E.CUADRA Managua, Nicaragua. c.a.
Sep 25, 2011 | Exercise & Fitness
5,200 BTU unit. Compressor and fan both work when first turned on, then compressor quits after 5-10 minutes of operation. Won't turn on again even after 5-minute fan-on cool down. Process repeats after AC...
this could be just a simple fix of cleaning the condenser coils. If semi-clogged, it can cause higher than normal pressures and cause the compressor to cut out on it protector. Check it out.
Jun 11, 2010 | Heating & Cooling
My unit dont turn on. it look like it is on, since the green light are on, but the unit dont cool neither make any noise
Hi, I looked up this unit, 5 to 8,000 b.t.u's about 1/2 of cooling, good unit. You say its not doing anything at all like maybe blowing just warm or room temperature air, or just a green light is on and its dead in the water? It didn't give me anything on stats for this unit, but you must have power to the unit. What I would do first, is to find the breaker that controls the plug that you run it on, turn it off for about 7 to 10 minute's, and reset breaker to see if there's a change. If you are a handyman or lady, you can try, since this is a newer model, try after pulling the plug, removing the front cover. Take the knobs off. Where the knob for the thermostat control is mounted, you should find some screws and a metal plate you can remove and this is where you will find your wiring control compartment. Look for any reset in the area, or possibly they may have a portion of this unit fused on the circuit board like they do on the larger circuit boards. Look for any signs of burned or blacked areas in the electrical area also. If not, we will have to go from there and take the steps to trouble shoot deeper into the system to find why you have power as the led light is on, but something has taken place. Keep me posted, and start at the main power supply like I asked first and we will go from there. Let me know what you find.
Sincerely,
Shastalaker7
Jun 02, 2010 | Kenmore 75085 Air Conditioner
Own 2005 27.5' Wildwood Trailer with a Dometic a/c ducted unit. Last few times out it freezes up initially first few times (pocked circuit breaker once then I turned it off after few minutes second time)....
Don't block off any ceiling ducts and see what happens. If you've closed off any forced air ducts, the unit will freeze up, if too many are closed off. Also, if you shut unit off (compressor) give it 5 or 10 minutes before you turn it back on.
May 21, 2010 | Dometic Rooftop RV Air Conditioner
A/c turns on for 10 minutes
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Turn on the and it begins to cool for about 10
Possibly your compressor overload is bad. A cheap and easy to replace part mounted on top of the compressor.
Jun 05, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Sunbeam SCA103RWB1 Room Air Conditioner Logo
139 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
