Question about Compaq Presario 5000 PC Desktop
Hard disk i got a hard disk but it work as a slave drive  but not a master drive i want to take out my old hard disk and put it into my comp but it doesn't work is there some how you can make the slave drive into a master
  • 640 Answers
You have to have both drives share the ide cable.on the back of each drive you will see a jumper,you will also see markings cs,mas,slave.the drive you want as master use the jumper on cs (cable select).the drive you want for slave use the slave jumper.if you just want to use your new drive put the jumper to cs first if that doesnt work put the jumper to master.
Posted on Jan 07, 2008
Foxconn p4m800p7ma-rs2 motherboard on Gforce FX5500 system halted
You refer to Master/Slave disks. Are you actually using the Master/Slave jumper settings? Must motherboards and OSs today recommend putting the disks in the CABLE SELECT jumper setting. The problem with the old Master/Slave setting is that the Controller on the Master Disk is used to control the Slave disk as well. This can lead to problems when disks are made by different manufacturers, as sometimes they are not fully compatible. In CABLE SELECT, each disk controller works independently.
Dec 30, 2011 | Foxconn Computers & Internet
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
How do you transfer hard drive from old comp. to new?
For just the data, get an ide to usb converter and connect it to the new computer, and just drag and drop.
You cant move an entire hard drive to a new computer because of driver issues, but you can use windows built in files and settings transfer utility.
IDE to USB: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
Dec 30, 2009 | Gateway 700 XL PC Desktop
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Win98 hds in win xp dont show other program says not formatted
you will need to revert back to the master/slave setting.  As slave/slave neither disk will be the main controller. Try reverse the master disk to the slave, and the slave to master, as it may be that the controller has a fault which is why you were having the original win98 problem.  Let me know how you get on
Jun 20, 2009 | Computers & Internet
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one...
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Mar 31, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Compaq Presario 5000 PC Desktop Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
