Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Can't use "plug&play" from TV menu
I just bought a Samsung LCD TV 32 and the tv was accidentaly set up in shop mode. I wanna change to home mode but the "plug & play" function is inactive. How can i fix that?
  • gav m Aug 15, 2008
    Hi i have just bought a second hand samsung lcd tv model LE32R87BD and i have the same problem. I put the tv in standard mode and after about 15 mins it switches to dynamic and resets all my settings. i have just tried that solution now and im waiting to see if it changes back again. I will let you no if it works, thanks Gav
Hi iv just bought a second hand samsung lcd tv, mine is in shop mode and it keeps changing from standard mode 2 dynamic and then resetting all my settings after about 15 mins. Im just trying doing that now, just waiting 2 c if it goes back again. I will let u know how i get on, thanks Gav
Posted on Aug 15, 2008
    I dont believe it, it has worked im so happy. I was worried i had bought a faulty tv, touch wood it is gonna be fine. Thanks so much for this you have made my day. I had never heard of this site, i will have it bookmarked from now on. thanks again Gav M
    You need to make sure the tv is not in digital tv when you change from shop mode.
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Posted on Jan 25, 2008
Can't access plug and play menu
On my 46 inch Samsung its was only accessible when you select TV input. I need to take the set out of the default store demo and put it into the home user mode. This did work for me.
Apr 06, 2013 | Samsung LN32A330 32 in. LCD TV
Accidently entered into store mode, but cant enter "plug and play"
hi, let try this.
Open menu , choose setup - push enter.
Choose plug and play, enter language , pass code, than follow instruction until setup home use and demo store appear.
Choose home use.
Its work with my TV.
Mar 18, 2011 | Samsung LN32A330 32 in. LCD TV
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
My Samsung LNT3253H LCD TV has suddenly started changing its own settings (e.g. picture mode keeps switching to ''dynamic'' and the ''light effect'' keeps setting itself to ''always on''). Any thoughts on...
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Sep 05, 2009 | Televison & Video
How do I switch off the feature that auto adjust the Brightness every 30 minutes - Its a samsung le37r888d - tanks
The TV is in whats called Shop Mode or Store Demo.
To remove this, you can etiher go back through the Plug & Play option via the Menu and Setup option.
Alternatively, if you press the Volume + on the side of the TV, then press and hold Menu until the screen goes blank, this will change the TV to Home Mode or Home Use and stop the settings resetting every 30 mins.
Jul 15, 2009 | Samsung TSK2792F 27" TV
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Samsung 933HD TV - Sound Switches On Automatically
Seems like the auto upgrade in standby mode feature was the culprit.
Switching this off from D MENU>SET-UP>SYSTEM>SOFTWARE UPGRADE did the trick.
BTW my firmware version is T-TMDEUC-1003
Nov 15, 2008 | Televison & Video
Don't store tv setting LCD40F86BD
im having the same problem, i have had this television for 16 months now. its not just happening when i turn it off but also when im changing the source
Jun 12, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung lcd tv le32r8 (Picture - Movie setting)
The TV is probably in Shop mode, when your TV is initially turned on you can choose between Shop mode or Home Mode.
In Shop mode the TV automaticly returns to the standard setting after a while, they do this so customers can "play" with it.
Press down de Volume button and then hold down the Menu button for five seconds on the side panel of the tv.
Oct 25, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
315 people viewed this question
Jerry Greenberg
Jerry Greenberg
