Solution #2
posted on Nov 11, 2009
Rank: Guru
Expert
Rating: 92%, 19 votes
METHOD ONE:
Through the Local Group Policy Editor
NOTE This method is only available for the Vista Business, Ultimate, and Enterprise editions. See Method Two below for the Vista Home Basic and Home Premium editions.
1. Open the Local Group Policy Editor.
2. In the left pane, click on Computer Configuration, Administrative Templates, Windows Components, and Windows Mail. (See screenshot below)
3. In the right pane, right click on Turn off Windows Mail application and click on Properties. (See screenshot above)
4. To Enable Windows Mail -
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Disable Windows Mail -
A) Select (dot) Enabled and click on OK.
6. Close the Local Group Policy Editor window.
METHOD TWO:
Through the Registry
NOTE This method will work for all Vista versions.
Option One: Through a Download
1. To Enable Windows Mail -
A) Click on the download button below to download the Enable_Windows_Mail.reg file.
B) Go to step 3.
2. To Disable Windows Mail -
A) Click on the download button below to download the Disable_Windows_Mail.reg file.
3. Click on Save, and save the .reg file to the Desktop.
4. Right click on the .reg file (on Desktop) and click on Merge.
5. Click on the Run button in the Security Warning pop-up.
6. Click on Continue (UAC), Yes, and then OK when prompted.
7. When done, you can delete the .reg file (on Desktop).
8. Log off and log on, or restart the computer to apply.
Option Two: The Manual Way
1. Open the Start Menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. Click on the Continue button in the UAC prompt.
4. In regedit, go to: (See screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft
A) In the left pane, right click on Microsoft and click on New and Key. Type Windows Mail and press Enter. (See screenshot below)
NOTE: If you already have Windows Mail in the left pane, then skip this step 5A and go to step 5B instead.
B) In the right pane of Windows Mail, right click on a empty space and click on New and DWORD (32-bit) Value. Type ManualLaunchAllowed and press Enter. (See screenshot below)
F) Go to step 7.
6. To Enable Windows Mail -
A) In the right pane, right click on ManualLaunchAllowed and click on Delete. (See screenshot above)
B) Click on Yes to confirm deletion.
7. Close regedit.
That's it,
Hope this helps, Best Regards, -md
