Loud buzzing sound
Hello
My 2 year old DLP has developed a loud buzzing sound. We then lost picture and the manual indicated lamp replacement. I did this and after alot of on/off the new we started getting a picture but the buzzing continunes.
Would really apprecite some assistance... [email protected]
Thank you
Regards
Jack
    President:
  • 3,130 Answers
It is the color wheel. A very common problem with these light engines. I would suggest you to call in a tech to handle this repair.
Posted on Jan 08, 2008
    Genius:
  • 1,139 Answers
Hello Jack,
That buzzing might be two things. It could be the color wheel or the ballast for the bulb. To check this you will have to move the projection section of the TV out of the case and listen for the sound in the area of the color wheel and the ballast. Try removing the color wheel power to see if the buzzing stops if it does then it's the color wheel is not and the ballast is buzzing then It's the ballast, and it will need replacing or if you know electronics you could try fixing the old ballast (I would suggest getting a new ballast).
Better still if you are uncomfortable working on the set you could get a qualified TV repair person to repair your TV .
I hope this helps,
Thank you,
Shuttle83
6ya staff
SOURCE:
When TV is turned on the picture has become darker. This has been going on for a few days and its getting worse.
This sure sounds like a bad lamp. If it is over 3 years old change it.
Also, listen for loud buzzing sounds that may indicate a bad color wheel.
But this definitely sounds like a lamp that is about to go bad.
Feb 10, 2011 | Samsung HLS4266 TV
Samsung 60" DLP - 6
Hello.
It looks like you ignored lamp replacement in your TV. It have to be replaced every 2.5 years of average use. It's like oil change in a car. Regular scheduled service.
You can read info about lamp replacement in your TV owner's manual, buy lamp on-line and replace it by yourself to save some money.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
My Sony Grand Vega (KDF-E50A10) LCD just made a loud pop sound and now there is no picture. The only sounds are a loud buzzing coming from the back....is this a burned out lamp??
Yes, loud pop sound was broken lamp in tv, replacement of lamp will fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 02, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Flickering screen, loud buzzing sound, self boot down.
Color wheel bad. Makes rumbling sound. Bad bearings. Has to spin about 10,000 RPMs and sync to DLP chip. Here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5933777&smodel=HLR5067WX/XAA
May 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-P4663W TV. Last evening we heard a pop and then the screen started to shrink in size and a loud buzzing noise could be heard. The indicator lights on the front panel indicate that the...
After much research, it became apparent that the most logical culprit after the lamp was the color wheel. It has been replaced and the set is working again.
Aug 21, 2008 | Televison & Video
Loud cracking sound, and now, nothing
Hopefully its only the lamp. Inspect lamp for breakage. Lamp power supply ok??. Check any air vents (filters if any) before replacing. Lamp life is only a few thousand hours, easy to do in a year, 5-6hrs a day. Check your manual.
Oct 29, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
406 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
