I would advise not to use commercial cleaning kits as they can be abrasive and do more bad than good. They CAN scratch the laser eye.
This is more than likely your laser that is dead and its possibly a Samsung or Hitachi drive, be careful
when
buying a new laser because there is a lot of dodgy ones around at the minute which can damage your
machine or
at the very least will be inferior and not last long.
if your 360 reads DVD's but not games it may be repairable but if it wont read anything then your better
off replacing the laser. strip down the console and strip the DVD drive, take out the laser and look
underneath it, it will have a code such as HD57 or something else, note that down. Visit ebay and search
for the laser with the same code, buy it, fit it in and make sure you de-solder the static blob of solder
before using it (search the net about this or ask the seller) and then try your machine again :)
This Drive will need to be cleaned or replaced try first purchasing a cd cleaning kit if that does not work a replacment drive will need to be purchased you can get a external hd drive for under $50.00 otherwise $150 for the internal one good luck
please leave postive feedback for your free answer today.
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo....
(More)
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo. I can play older titles.
my xbox is having the invalid format problem...happened while playing, the colors went weird so i...
(More)
my xbox is having the invalid format problem...happened while playing, the colors went weird so i turned it off. when i turned it back on it says invalid format but there is still audio, it sets up normally to the dashboard (i know this by the audio) and the power light is green as normal. after playing around with it a bit it no longer says invalid format but instead now says no signal at all. the rest still working normally. any ideas for advice or solutions?
the tray don't open or close you push the button and nothing happens and on the screen it will say...
(More)
the tray don't open or close you push the button and nothing happens and on the screen it will say opening or closing but its not doing anything so what can it be is it considered a tray or dvd drive is there something i can do. I want to get this fixed my son has never been able to play it. What a birthday present huh idon't know much about these i do know that when you push the button the tray should come out so you can put a game in it. Can someone help me
