Sounds like it could be plugged inlet. Where the hose goes into the washer. Try it on a different cycle, if it works on a different cycle then it is the timer.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Affinity ATF7000E
After 10-15 min after starting the wash when its in warm or hot - I get that beeping that states E10...
(More)
After 10-15 min after starting the wash when its in warm or hot - I get that beeping that states E10 The washer works fine when its run on all cold.
my washer does not want to spin out...it will wash but when i get to spin it stops...it also has a...
(More)
my washer does not want to spin out...it will wash but when i get to spin it stops...it also has a error code of E23 something with the interface board or loose wire . I check and no loose wire
door will not lock gives dr code I checked the door pins they are not broken and door is closing all...
(More)
door will not lock gives dr code I checked the door pins they are not broken and door is closing all the way machine is less than 2 years old with lite usage
