Question about Cobra PR-245/2 (7 Channels) 2-Way Radio
Cobra pr250 2 way radios
Both don't receive any signals from each other
    Brigadier General:
  • 6,966 Answers
Pls verify that both radios are:
1. within range of each other;
2. channel selection is identical;
3. CTCSS Privacy Code is identical;
4. Call Tone is identical;
5. Receive icon appears when the other radio's PTT is pressed;
6. Auto Squelch/Max Range is set to receive even weak signals.
Please correct settings if needed.
In some cases, it is the internal speakers that goes bad.
Hope this be of help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 08, 2008
I have audio but no video
This depends on the signal source. If it is digital, from a digital receiver, the audio will be either S/PDIF or Optical and the video will be a yellow RCA connector (co-axial). If analogue, the audio will be two RCA connectors (red-right and white-left) and the video will be component (green, blue, red RCA) Alternatively you may have a composite audio/video signal (yellow) which is both audio and video. Of course you must be sure to choose the inputs into which you have plugged your signal source. Cheers, Don.
Nov 25, 2013 | Denon AVR-2106 Receiver
Gps 60csx don't get satellites signal level
use the webupdater and replace GPSChipsetTypeG file.
Kind Regards,
Silva.
Dec 08, 2012 | Garmin GPSMAP 60CSx GPS Receiver
I have sound but no picture. I'm on direct tvI and don't reslly know if its the tv or the dtv receiver. I'm using a hdmi cable. any suggestions on how I can isolate the problem to either the tv...
Hello
Give signal to TV with other devices. Feed it the signal from a DVD player, and see whether there is picture and sound. If it is OK; be sure that the problem is with DTV receiver. OK.
Jun 19, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
NO SIGNAL NEW BATTERY STILL DON'T GET ANY SIGNAL
just a guess but something to try theres usually a sync button on the bottom of the mouse and one on the receiver, press receiver then mouse.
May 09, 2011 | Logitech Cordless Mouse
Hello, the gps signal is not working on my tom tom one n14644. I've tried numerous attemps to find the signal, but I am unsuccessful, can you guys help me?
I am glad to HELP YOU!
I'd suggest you - first thing first - to make sure your TomTom device is getting the proper signal. Maybe in the area where you've tested it are too many tall buildings or too strong magnetic fields. So I'd say to get your device in a park or even outside the city/town limits and to retry to acquire the satellites signal.
If you will have the same result that will lead to the opinion that the GPS receiver itself it's damaged and must be replaced.
If your device is still under a warranty terms & conditions - then take it back to the dealer and ask for a total replacement or for a total refund. DON'T TRY TO FIX BY YOURSELF THE GPS RECEIVER! It's too fragile and maybe you will end up with a useless device...!
Anyway - before any attempt make sure your TomTom battery IS FULLY CHARGED!
My best regards!
... and don't forget to RATE, please...
Apr 20, 2011 | Tomtom ONE GPS Receiver
What setting to receive fax
You don't have to manually set the printer to receive faxes. Your printer will automatically receive a fax when it recognizes a fax tone/signal/transmission. Just as long as the fax settings are correctly configured and the printer is connected to a working phone/fax line.
Apr 12, 2011 | Lexmark X6575 All-In-One InkJet Printer
Not receiver signal
Maybe you need a digital converter for your t.v. Most car t.v's only pick up ntsc,pal. The new digital is atsc.
Jun 14, 2009 | Car Audio & Video
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Sony a/v reciever not sending video to tv.....
I don´t know if I´ve understood, but the best way to "pass" video signals to TV through receivers is using a stereo VCR, where you plug in any antenna. Then you connect VCR´s audio and video channels to the receiver. Turning on all equipment, select video1 source. You will hear sound through the system and watch video signal on TV. Hope this may help.
May 22, 2008 | Sony A/V Receiver
32PW878 don´t replay to the remote control orders
You are checking signals at the micro in the TV set? I would first suspect a noisy remote receiver then before replacing other costly items.
Apr 19, 2007 | Philips 32PW8608 32" TV
Cobra PR-245/2 (7 Channels) 2-Way Radio Logo
121 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
