The ink system failure is caused by air in your ink feed lines. We have a step by step repair guide posted on our web site at: www.ccl-la.com Look in the printer repair section. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Thank you so much! Your step by step solution worked perfectly and got me up and running again. Fantastic assistance and prompt response time.
" - rellagberman
Popular Solutions for HP Photosmart C6180 All-In-One
how do i fix my printer when i pressed the power button and it says shut down but it doesn't shut...
(More)
how do i fix my printer when i pressed the power button and it says shut down but it doesn't shut down
having problems with outlets inside the house no current on then, but main circuit breakers are Ok,...
(More)
having problems with outlets inside the house no current on then, but main circuit breakers are Ok, have current coming out from black wire.
Need a description of functions for the buttons on the front panel display for the HP Photosmart...
(More)
Need a description of functions for the buttons on the front panel display for the HP Photosmart C180 Printer.Need a copy of the manual.
HP Photosmart C6180 All- In- One Printer keep coming up with Ink System Failure: Error: 0xc05d0381 I...
(More)
HP Photosmart C6180 All- In- One Printer keep coming up with Ink System Failure: Error: 0xc05d0381 I do what it tells me and it still doesnt work.
