Frigidaire FEB27S5A Electric Single Oven Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We (Eual & Pannett Hall located in Baton Rouge, LA purchased an FEB4s2asb Frigidaire Electric Oven. It would not bake food brown. It was replace with another one and it will not bake anything brown either. Now we have to take our food to other locations to bake pies or cakes brown. It there any advice you can give me th resolve this problems. We can be contacted at (225) 357-8568 or reply to this e-mail. We are totally discussed with this oven. The name Frigidaire makes us want to scream. Can you help us? Pannett & Eual
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Nov 11, 2009
Anonymous
Master
Level 3:
Answers
725
Questions
0
Helped
167221
Points
1617
I will speak to my service manager in the morning and call you to tell you why we think you are having a problem like this.
It must be very frustrating but I hope to be able to resolve this problem for you with a simpe solution.
Frigidaire is really a great brand so I feel like it is not the brand that is causing this issue for you.
You will hear from me tomorrow. Just relax. Thanks, Ella
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 • Ovens
Oven taking too long too bake.
If you still have your Frigidaire Oven there is an reason why it take longer to bake. Frigidaire Oven has an safety limit control inside the oven and it is place on top of your oven. We know that the heat go up,so that control is cutting the heat will the thermostat is asking for heat.I had a Frigidaire oven, I change 2 control a the end a purchase a new one. When I scrap the old one I notice that problem,
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
3helpful
Everything works fine except it does not heat up at all. Convection fan, Oven lights, Control panel all work an act as expected. I tested the Temp probe at 2K ohm an got 1.066. any help would be great. Is...
Hello there:
Here are two instances of when food "bakes poorly:" or not at all When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
My 4 top elements work but my oven doesn't.
Take the back cover off the range. Locate the bake element terminals near the bottom of the oven. Turn bake on and check for voltage. If no voltage then replace control board. If voltage is good, then unplug oven and check for continuity. If no continuity then replace bake element. Also, does broil element work or is it dead as well? If both oven elements are dead then the control board is most likely at fault.
2helpful
Wont heat past 200 degres
May 27, 2009 • Ovens
Frigidaire model number FGF356MXAWR, Serial #VF34511587 oven
it is probably the bake ignitor needs replaced. the only way to check it is with an amp meter. however, this is a part that does fail alot, and you can buy one for pretty cheap. it is located mounted on the bake burner by 2 screws. and it only involves splicing 2 wires, (the wire nuts you need should come with the new ignitor)
Supressor, transient
Hello hward,
Welcome,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Huuum
Thank You ,Please remember to leave a rating
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
