Question about Canon PIXMA MP180 All-In-One InkJet Printer
Printing When i try to print the corner of the paper is only pulled from the right side and is not taken through the printer. The printer then says the paper is jammed. How do i fix this problem?
  • gfrizzle Feb 05, 2008
    Exact same problem here. All of a sudden it's pulling from the right side and crumpling the paper every time. There doesn't appear to be anything blocking the path of the paper. I would love to know what's gone wrong all of a sudden.
  • richcap Feb 08, 2008
    I have the same problem, please can somebody help before i throw the junk out the window.................
  • 2,985 Answers
Enter your printer make model and go to the forum
Posted on Jan 08, 2008
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
Canon pixma pro 9000 - when printing the paper goes in a couple of cm and gets caught (on the right corner) and tilts to the left side I can hear the rollers spinning but printing ceases
Hello! To solve your problem follow the instruction. 1. Paper must be straight, don let them curve. 2. Paper must not wet, should be tried. That is the only way to solve problem.. good luck
Sep 09, 2011 | Canon PIXMA Pro9000 Printer
Hi Where do I load the paper in my Canon MX310?
The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: .
I hope this helps.
Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Follow the steps:
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
Print your documents as needed.
Paper Cassette :
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
Pull on the cassette on the bottom of the printer to slide it out of the printer.
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Paper wont feed propaly
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
May 26, 2009 | Canon PIXMA MP520 InkJet Printer
Do not continue this way, you are sure to ruin your paper sensor or the like. Most probably you have a paper jam inside near the carriage or roller. Open at front, check inside for paper jam.
Jan 22, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
Paper jam
Do the rollers need cleaning or lubrication? Mine pulls on the left hand corner facing the printer
May 11, 2007 | Canon i250 InkJet Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
