Texas Instruments TI-83 Plus Calculator
Problem for Texas Instruments TI-83 Plus Calculator
Need help on scientific notation\r\nusing a texas
By ebhacker on Nov 11, 2009
need help on scientific notation using a texas instrumants ti-83
Solution #1
posted on Nov 18, 2009
Not Rated)
k24674
Rank: Guru  Office Equipment  Expert
Rating: 87%, 725 votes
The basics of scientific notations are as follows.
Every quantity is represented by
  1. A mantissa multiplied by
  2. a power of 10
The mantissa is a number that has
  • 1 digit (1,2,3,4,5,6,7,8,9) followed by
  • the decimal mark ( dot or comma) and by
  • several decimal digits (depending on the configuration of your calculator
The power of 10 is made up of
  • the E symbol, followed by
  • a small minus sign or no sigh if exponent is positive
  • an exponent with 1 or 2 digits
Ex:
1 is displayed as 1E0 meaning 1*10^0
10 is displaye as 1E1meanibg 1*10^1
100 is displaye as 1E2 1*10^2
0.5 is displaye as 5E-1 (the 5 is in first position after the decimal mark)
0.07 is displaye as 7E-2 ( the 7 is in 2nd position after the decimal mark)
0.004 is displayed as 4E-3 the 4 is in first position after the decimal mark)
333.25 is displayed as 3.3325 E2
To enter number in scientific notation
On you calculator you should not use the [^] key to enter powers of 10, you use a short cut key [2nd] [EE]
If you have done some chemistry, you might have seen
  1. Avogadro's Number Na =6.02 * 10^23
  2. You type 6.02 [2nd][EE]23
  3. you see 6.02 E23
The electon charge 1.6*10^(-19)
  1. You type 1.6[2nd][EE] [(-)] 19; the [(-)] id the change sign (under the [3] key)
  2. You see 1.6E-19
You can verify that the two numbers I used as exemples have
  • a single digit before the
  • decimal mark,
  • one or more digits after the decimal mark,
  • the power of 10 (*10^ or E on calculator),
  • a minus sign or no sign
  • up to 2 digits in the exponent.
Hope it helps.
Comments:
Nov 23, 2009
- OOPS;
Ex:
0.5 is displayed as 5E-1 (the 5 is in first position after the decimal mark)
0.07 is displayed as 7E-2 ( the 7 is in 2nd position after the decimal mark)
0.004 is displayed as 4E-3 the 4 is in third position after the decimal mark)
Was this helpful?
Yes
No
Solution #2
posted on Nov 11, 2009
Not Rated)
thushanth
Rank: Apprentice  Office Equipment  Expert
Rating: 87%, 2 votes
http://www.ehow.com/how_4667397_enter-scientific-notation-ti-calculator.html
still have problem's mail me at thushanth@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-83 Plus
Questions and Unsolved Problems for Texas Instruments TI-83 Plus
Do you recommend Texas Instruments TI-83 Plus Calculator?
Answer
Answer
im putting in a numbers to my L1 and L2 lists but when i hit graph nothing appears on my graph. i... (More)
Answer
when i turn on my calculator, it displays the negative sign and the blinking cursor, but the buttons... (More)
Answer
TI-83 Plus has dead pixel lines. It went unused for a little while, when booted back on it had one... (More)
Answer
New batteries, calculator won't turn on. It turns on occasionally but it's not consistant.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculators Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
