Question about Cat5e 7 FT 350MHz Snagless RJ45 UTP Network Patch Cable (CAT5E350MHZ7FT)
Can i transmit +12v through CAT cables?
My communication is a 4 wire communication and I am using a RS485 standard. IS there any standard pinouts for RS485 connector?
Out of the 4 wire, two wires are for + and - Differential signals. One wire for ground and other for Vcc. Can i transmit +12v through 4 wire CAT cables?
  • Mohmed Anees Feb 15, 2008
    It would be helpful if you send me any links/Proof for the 12V and 40meters distance..
  • 3 Answers
Describe your problem more correctly.
As i`ve understood i`re trying to transmit 12V via standart UTP Cable?
If it`s so - you can transmit 12V up to 40 meters length on this type of cable, if the current isn`t bigger than 2 A
Posted on Jan 08, 2008
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Microsoft Lifechat-LX-3000 , the wires got pulled out of the headset USB side , what colors go where ?
You can see if the wire is made corresponding to the USB 1.x/2.0 standard. (All USB cables should follow the standard, but many manufacturers don't respect this and use whatever cables they get cheap.)
The Pin-out and wire colors can be found here:
USB Wikipedia the free encyclopedia
(scroll down to "Pinouts", also provided below)
USB 1.x/2.0 standard pinout
1 VBUS Red (or orange) +5V
2 White (or gold) Data?
3 Green Data+
4 GNDBlack (or blue) Ground
Hope this helps!
Feb 17, 2013 | Microsoft LifeChat™ LX-3000 Headset
Needwiring diagram for a avc fan da12025b12l
I have two articles on this, neither of which correspond to what I said in another answer.
Dell use or used to use a non standard pin out (so it will depend was made by AVC especially for Dells)
In the standard pin out the black wire is 0V, the next often yellow is +V (12V for your fan) the third one is speed sense, and the final one is speed control (you search the internet under 4-pin fan pin-out to be more confident.)
Two article are
http://www.formfactors.org/developer%5Cspecs%5CREV1_2_Public.pdf (section 4.1.6)
and
http://www.setiusa.us/showthread.php?2480-PWM-Fan-Pinouts-Industry-Standard-amp-Dell-configurations the picture drom the second article I reproduce (without permission).
To be certain consult your m/b manual which should all the pin assignmens on your m/b, or you can try to measure the voltage between 0V and the second pin to verify that it is +12V in your case (it may be lower or as high as 13.2V)
Dec 13, 2012 | AVC 12v dc 0.7a 70x15mm 3-wire fan...
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
I only want to know the meaning of the different colours of cables that are used in crossover cables?
the standard colours for CAT5(e) or CAT6 ethernet cable are:
green, green stripe
blue, blue stripe
orange, orang stripe
brown, brown stripe
the typical setup for an ethernet connection in an RJ45 (the crystal end with the connection tab towards you) is
2 green
3 orange stripe
4 blue
5 blue stripe
6 orange
7 brown stripe
8 brown
Wires 1 & 2 are used to transmit data from the PC to the router/modem (TX) and wires 3 & 6 are used to recieve information from the modem/router (RX). in this fasion, information flows along one pair or another and is expected to arrive at that pinout. the router/hub/modem takes care of the transition to the next cable or out to the internet.
In a crossover cable ONE end is configured as above, but the colours for wires 1, 2, 3, and 6 are exchanged so that when no hardware is between the two PCs/components the signal is transmited at wire 1 & 2 and recieved on pins 3 & 6 on the other system/component. the other colours are placed for backward compatibilitiy and other applications, such as power over ethernet.
following the standard above allows anybody familiar with RJ45 connections repair a connection with a standard colour code and pattern without having to see the other end. If you know you need to replace one end of a patch cable, you use the standard termination.
Oct 12, 2010 | Computers & Internet
Max cable lenght for cat 6e cable
The cable standard provides performance of up to 250 MHz and is suitable for 10BASE-T / 100BASE-TX and 1000BASE-T / 1000BASE-TX (Gigabit Ethernet). It is expected to suit the 10GBASE-T (10Gigabit Ethernet) standard, although with limitations on length if unshielded Cat 6 cable is used. Category 6 cable can be identified by the printing on the side of the cable sheath.
Cat5e is suitable for 10/100/1000baseT ethernet for 100 meters, when properly installed.
Cat 6 is also good for 10 gig ethernet for 37 meters, but that is pretty short, unless just in a server room.
There is no Cat 6e, but Cat 6A will be good for 10/100/1000/10GbaseT ethernet for 100 meters.
Unshielded Twisted Pair has no ground shield around the wires. It is the standard in the US, where most network standards were defined. There are extensions to the standards to allow for the more common in Europe, Shielded Twisted Pair.
Some Cat-6 cables are too large and may be difficult to attach to 8P8C connectors without a special modular piece and are technically not standard compliant. If components of the various cable standards are intermixed, the performance of the signal path will be limited to that of the lowest category. The maximum allowed length of a Cat-6 cable is 100 meters (330 ft) when used for 10/100/1000baseT and 37 meters (120 ft) when used for 10GbaseT. This applies for UTP cables only. Shielded Cat 6 and Cat 7 cables are capable of 100m.....sodeep
Jul 30, 2009 | Cables Unlimited CAT6 (UTP-7220) (UTP7220)
RS-422 connection RJ12
What I was told through the mfg. was:
pins 1,8 =NC
pins 2,7= Chassis Ground
Pin 3= TX-
Pin 4= TX+
Pin 5= RX-
Pin 6= RX+
This would actually be a RJ45 (8pin) but uses the 6 pin cable and only 4 com wires.
Evidentally there is no standard for the pin usages for serial communications with RJ connectors. So this information might not be valid for other equipment.
Jan 20, 2009 | 3Com Computers & Internet
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
HOW DO I CORRECTLY WIRE THIS WALLPLATE TO MY CAT5e CABLE AND PHONE LINE. WHAT COLOR BELONGS TO WHAT?
http://www.ertyu.org/steven_nikkel/ethernetcables.html
this link covers proper pinout for cat 5 cabling. (RJ45). A phone line is RJ11. You can run ethernet cable through a wall and terminate it at a wall plate designed for ethernet (not a standard phone wall plate). You can't use the RJ11 cable currently in the walls for ethernet.
May 02, 2008 | Computers & Internet
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
Computers & Internet Logo
130 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
