I have a G4 ibook. When I try to load Rosetta Stone on computer it acts like it wants to load but then all the sudden it goes to a blank screen. If you can help please do. The software worked the first three times I used it.
Isolate the problem to make sure its not the optical reader. Get a music CD and try to see if it will play, then get a DVD out to see if it will play, then get another software disc to see if it will play. Will all three play fine? Then your Rosetta disc is fu.k.d up from heavy scratches, smudges, or corrupt manufacturing process.
Otherwise, your optical drive needs to be replaced if it has problems playing the other discs.
cleaned the keyboard with the spray, and now my laptop does not work, is it possible that oksidirao...
(More)
cleaned the keyboard with the spray, and now my laptop does not work, is it possible that oksidirao and can not be repaired
I had a cd stuck in my intell based macbook. I stuck in a piece of thick folded paper and just...
(More)
I had a cd stuck in my intell based macbook. I stuck in a piece of thick folded paper and just brushed it around a little, and the cd came out enough to grab it and pull it out, found similar solutions in this forum!
