Texas Instruments TI-83 Plus Calculator
Problem for Texas Instruments TI-83 Plus Calculator
When clicking on graph button screen shows invalid
By tiffany_bene on Nov 11, 2009
When clicking on graph button screen shows invalid dim
How do i fix this?
Solution #1
posted on Nov 13, 2009
Not Rated)
MrTumbleweed
Rank: Master
Rating: 88%, 6 votes
Your poor calculator just can't seem to fit the values you want onto your graph without risking unsightly stretch marks. To fix this, either press the "ZOOM" key and return to "ZStandard", or press "WINDOW" and define more acceptable (or possible) dimentions.
Was this helpful?
Yes
No
Solution #2
posted on Nov 11, 2009
Not Rated)
thushanth
Rank: Apprentice
Rating: 87%, 2 votes
This message has several possible causes.
  • If you get this when making some kind of plot, you probably forgot that you have one of Plot1 Plot2 Plot3 turned on, and it refers to two lists that don't have the same length. The cure is to press [Y=] and turn off the unwanted plot.
  • If you’re actually doing something that needs lists, such as a regression, but your lists don’t have the same length, you get this message. Press [STAT] [1] and check your lists.
  • You also get this message when you give the TI-83 a list or matrix where it expected a variable or number, or vice versa. For instance, on the STAT PLOT screen, you may mean to press [2nd] [L1] but if you miss the [2nd] you actually type a Y. In the same way you might type a Z where you intend to type L2.
  • Karl Wein offers another possibility. You can create a list called L1, but that is not the same as the predefined list called L1 (note the small-capital L), and of course similarly for lists 2 through 6. If you accidentally delete a predefined list from the editor, make sure to bring it back with the SetUpEditor command.
In general, when you see this message you need to check carefully through what you’ve done to make sure that you used lists where you were supposed to, and nowhere else.
DON'T THANK ME THANK http://oakroadsystems.com/math/ti83oops.htm#InvalidDim
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-83 Plus
Questions and Unsolved Problems for Texas Instruments TI-83 Plus
Do you recommend Texas Instruments TI-83 Plus Calculator?
Answer
Answer
Hi, so my batteries died and I replaced them with brand new batteries (and yes they're in the... (More)
Answer
Haven't turned it on in a while and replaced batteries. Came on once with a completely dark screen.... (More)
Answer
On my TI-83 plus calculator when i try to use the graphing tool it says err:invalid dim 1:quit what... (More)
Answer
one line of my calculator won't work log 7 8 9 x
Answer
When [ON] is pressed, the screen appears black (most times, but occasionally works). Contrast... (More)
Describe your Calculators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculator Experts
Top Copier & Fax Repairmen
in , TX
(805) 813-1755
Full line Canon, Konica/Minolta, Panasonic and HP...
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
