First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST A NEW QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on
ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
how to install a hard drive into a avic z-1. i bought a upgraded hard drive for the avic z-1 to...
(More)
how to install a hard drive into a avic z-1. i bought a upgraded hard drive for the avic z-1 to bring it to a z-3. and the guy forgot to send instruction on how to install it. can someone please help
when i use ma kingston usb in laptop it works properly but when i use it in my car sterio somtime...
(More)
when i use ma kingston usb in laptop it works properly but when i use it in my car sterio somtime stuck n somtime works. why is this so?
I just had a Kenwood KVT-512 installed with the Bluetooth 200 and I can't seem to make the voice...
(More)
I just had a Kenwood KVT-512 installed with the Bluetooth 200 and I can't seem to make the voice command work or be able to use the key pad on the 512 screen. Is this because my phone is to old.
what is out frequency response or cross-over if I use the sub output to connect to a self-powered...
(More)
what is out frequency response or cross-over if I use the sub output to connect to a self-powered subwoofer? Will this remove the lower end from the other speakers [hope so]
