Is the light on the power supply? if so is it red, green or amber? this can help. If its red it could be either the power supply which is faulty or a major problem with the 360 which is causing a short or something similar. What is probably wrong witht he 360 is the 3rrod:
When the Xbox 360 overheats it causes the lead free solder to crack, the more that crack the worse the machine will get. So eventually I suspect your machine will die completely and show either 3rrod or e74.
To remedy this you need to strip the console down and replace what's called the X-Clamps, at the same time replace the heat-sink paste and then you need to re-heat the whole board. We use a special IR over which re-bakes everything and re-seats the solder properly, a lot of people use a heat-gun but you have to be very careful.
Trying to run XBox360Live directly through a Toshiba PCX2600 Modem andet the MTU must be 1364 error,...
(More)
Trying to run XBox360Live directly through a Toshiba PCX2600 Modem andet the MTU must be 1364 error, how can I determine if this modem is 164 or higher?
For some reason my xbox 360 will not turn on. So before I begin, let me tell you what I did before...
(More)
For some reason my xbox 360 will not turn on. So before I begin, let me tell you what I did before this happend. So my 360 had red ring and so i brought into my copmuter repair class so they can fix it. They did the penny trick and when igot home, i realized one of the pennies had gotten loose. So after 2 hours of opening the damn thing, I finally got the motherboard and reglued the penny with silicon base thermal paste. So it took me a while to put everything back on and the console will not turn on! All the chords are in and the power brick is on orange. Some people say it might be the usb but i dont know what that is or where its located. Can anyone help me with my problem?
how do i connect steering wheel [ev8] to console, its got a round push in plug and i cant see...
(More)
how do i connect steering wheel [ev8] to console, its got a round push in plug and i cant see anywhere on console to fit it [ xbox original]
