Routers
Problem for Routers
Generic problem for all Routers
Sitecom router broadband wireless con...
By rupes on Jan 07, 2008
I've gone through the different stages of connecting my new router, first to my basic computer, then to my new laptop.
Internet connection works fine until I disconnect computer cable from modem and connects it the router.
But the router seems correctly installed, its green symbol showing and signals indicated as strong.
USB unit installed
Should I use PPPOE or PPTP?
Best Solution
posted on Jan 08, 2008
Very Helpful)
coach J
Rank: Guide
Rating: 91%, 8 votes
Most ISP may tell you that they do not support the Router! Log into the router and makes sure it clone the MAC address of your Laptop, and secure your Router by changing the password!
Have a great 2008!
Coach "J"
Was this helpful?
Yes
No
Solution #2
Very Helpful)
hughv
Rank: Wiz
Rating: 83%, 315 votes
This detail will be provided by your ISP.
DSL usually requires PPOE.
If you need morer info, supply the name of your ISP, the service provided and the Make/Model of the router.
Was this helpful?
Yes
No
Solution #3
Helpful)
DRSS
Rank: Guru
Rating: 87%, 100 votes
Hi FRND,
USB is hot plug & play device you doesn't need to restart or unplug!!
Install the driver CD provided by the router…Connect the router to computer…
It will automatically install the router and generate the Port for the internet connection… After this just login in to the router and change the setting by which the ISP gives you (IP Address) restart the router for setting applied after this connect the Internet and enjoy….. J
Was this helpful?
Yes
No
Solution #4
Helpful)
senyo
Rank: Wiz
Rating: 86%, 42 votes
You don't need PPPOE for router because its used for encapsulating PPP frames in a dial up connection, and thats where the modem is used.
you will only use PPTP if your ISP is using the PPTP server...
so my advice is that you contact your Internet Service Provider for confirmation.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
jessee007
Rank: Wiz
Rating: 79%, 237 votes
This is a basic fix. Only usb is plug and play. If you unplug the eathernet cable it will require a reboot of the router and possably your computer. To reboot the router just unplug the power cord from the unit for 30 sec or so.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
i am receiving unknown audio when i connect to the internet
Answer
My ipod touch will not connect to my home network, but will connect to other networks. The Apple... (More)
Answer
Router won't reset and is not pingable. When reset and re powered up, all the lights are green... (More)
Answer
I've been on a Dell XPS system and bought an IMac. During setup of the IMac I cannot find the router... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
