Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel Pentium D Processor T2080, 512 MB RAM, 80 GB H... PC Notebook
Problem for Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel...
My laptop couldn't start normally. it keeps on
By blbsantillan on Nov 11, 2009
my laptop couldn't start normally. it keeps on restarting. what should I do?
Clarification Request
Posted by fran29 on Nov 11, 2009
hit f8 and go to safe mood with networking if u have a anit virus run it on safe mood download tuneup untilities the 30days trail run that to that should sort it out for u
Posted by Lanijo58 on Nov 11, 2009
What are you referring to? Do you mean it starts in a safe mode? You may just need to do normal maintenance, like clearing cache and cookies, and disk clean up and defrag.
Solution #1
posted on Nov 14, 2009
Not Rated)
cleary1645
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with emachine all i did was get a copy of spyware doctor and registry mechanic and run registry mechanic from start up, may take a while but should sort it, then restart then run spyware and your sorted!!!
Was this helpful?
Yes
No
Solution #2
posted on Nov 11, 2009
Not Rated)
parrotheadpc
Rank: Guru  Toshiba Computer Hardware  Expert
Rating: 89%, 545 votes
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A135-S2386
Questions and Unsolved Problems for Toshiba Satellite A135-S2386
Do you recommend Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel Pentium D Processor T2080, 512 MB RAM, 80 GB H... PC Notebook?
Answer
Answer
i can not log to my account on my laptop and login passward is also correct but it shows only... (More)
Answer
i accidently uninstalled my camera assistant software for toshiba off my laptop can you help me
Answer
toshiba a305-s6898 computer starts up and goes to black screen what can fix this
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A135-S2386...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 741
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
