Question about Microwave Ovens
Samsung microwave oven (touch panel problem)
Good day! i'm from philippines, my samsung microwave is a touch panel operation model, my problem is, the buttons that we frequently use in not working now, like the, "one touch", the numbers "1, 3, & 0" and the "start" button. what will i do? we can't even cook the the microwavable popcorn...please help me
  • vsmurthy Dec 23, 2008
    i have got samsumg microwave model 83gl purchased nearly 2 years back.We have not frequently used the microwave.Touch panel bottons are not working like "start button" etc. some of the buttons are working,but the start button is not working, when contacted with samsung engineers they told that the touch panel is not working properly and they have even not coded the price of the touch panel. Now my problem is how that the touch panel of microwave gets spoiled when it is not frequently used.
  • Anonymous Mar 28, 2014
    How to Disassemble Samsung Microwave SMH9207ST door panel
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 547 Answers
If you have a membrane type keypad, you might want to look for a ribbon cable that runs from it to the circuit board. If you have one, try disconnecting it from the circuit board, and plugging it back in. If possible, spray a small amount of electronic contact cleaner on the connector as you do this. With a set of touch buttons not working, it's likely you have a wire which is not making a connection somewhere.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Jun 24, 2016
You can use the express button in touch pad,
Posted on Jan 20, 2008
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Code for samsung microwave
Can you please clarify what the main problem is so we can give you exact solution? I'm sorry I didn't quite understand what you mean. Thanks!
Oct 10, 2008 | Microwave Ovens
Samsung microwave ce1031lfb touch panel start not working
If your touch panel is not working, I would recommend replacing the microwave because the cost of purchasing a new panel may cost you more than what you could buy a new microwave. Sorry!
Aug 09, 2015 | Samsung Microwave Ovens
GE, Model# PVM2070SM1SS microwave - touch panel does not respond
GE has a special program, and your microwave is very likely a part of this program. Please contact GE consumer relations asap at 800-386-1215, at the prompt press 5. Our same microwave model has that problem. GE is replacing the entire microwave free of charge.
Jun 21, 2012 | GE PVM2070SMSS Microwave Oven
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
The touch panel pad of my microwave, model Combi, needs replacement. Pl. tell me its cost and the place nearest to Noida where i can get it. Thank you.
the cost for a new touch panel is around $80 fitted as i live in australia im not sure of the closest repairer to you but any good electronics repair shop who deal with microwaves can help you look in your local phone directory
p.s the only time we replace touch panels are when they are worn out if the buttons are not responding then the problem is not the touch pad this is a repaly problem but is cheaper to repair have them check as to the correct fault before asking to have the panel replaced
best of luck to you.. please rate this repair thank you
Aug 02, 2010 | Samsung Microwave Ovens
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
Microwave Ovens Logo
1,278 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
