Question about HP LaserJet 1020 Printer
Blank trace appears on printed copy
My laserjet 1020 was working perfectly well until about a week ago when i noticed that a balnk trace on the printed docs. Anyway, when i removed the cartridge and wiped it and shook, it printed well but only for a short while as not up to 30 print outs were done.This routine of wiping and shaking has been going on since then and really gets me pissed up. Do i have a ink problem or the print head has a prob?
  • PSGuru Jan 22, 2008
    This is happening to my new HP 1020 Laser as well. I bought a new toner cartridge and thought that had done the trick. It printed a few hundred copies so I stopped monitoring it. Then I checked again and about 50 pages had white blank streaks on the pages. Had to throw them away. So I know the toner is not the problem. I gently shook the cartridge and it was fine for about 20 pages then started happening again. Any ideas???
    I'm starting to wonder if it is just getting too hot. This printing was several hundred copies and I wait between every 50 sheets, but I may just need to let it cool down more.
    Help!
Help!
Posted on Jan 22, 2008
  • 233 Answers
Replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Posted on Jan 07, 2008
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
Blank page problem
press and hold the green button for 5 seconds to generate an internal test print... does it print? If it does its a driver issue... if it dosent check your toner ctg remove and reinstall
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jun 05, 2010 | HP LaserJet 1020 Printer
My laserjet 1020 has a paper jam output message, i followed the instruction that appeared on the screen, but still, the message appear when i tried to print, there is also a red blinking light
Try to press the reset button on your printer if did not works just try to download the reseter of your printer in HP Laserjet 1020 at the HP website. Because your printer have a lifespan printing; example if your printer have a 100,000 copies to be print so you have aloud to print not more than 100,000 copies. That's why need to reset your printer using the reseter program by HP.
May 26, 2010 | HP LaserJet 1020 Printer
Double printing or 'ghost' images
you need to change your toner opc drums
Dec 13, 2009 | HP LaserJet 1020 Printer
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
A faint curved ink line on each print copy
Slide the paper tray guides snug against the paper, and it should feed fine
Apr 23, 2009 | HP LaserJet 1020 Printer
Problem with vertical white line on HP laserjet 1020 printer.
there is probably toner on the laser. take a small vacuum cleaner and vacuum out the printer. DO NOT blow out the printer as it may scratch the mirror on the laser. Also take a cloth and some rubbing alcohol and wipe off all the visible surfaces inside the printer.
Mar 19, 2009 | HP LaserJet 5p Printer
Printer prints blanks lines
does it move to a different spot each copy? yes
replace drum
Aug 25, 2008 | HP LaserJet 1020 Printer
HP Laserjet 1020 - prints blank documents
in my printer the resistor R348 on the motherboard printer was broken. The value that must have is 10 ohms. I have changed and the printer has resumed work.
Dec 05, 2006 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
291 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
