Washer slow to fill, and will stop/pause prior to completing all cycles. This typically happens towards the end of all cycles. I've been reading and it looks like we may have a clogged filter on the water pump. I do not however know how to get to this on the machine if it is indeed the case.
Should I try by unscrewing the screws securing the front?
ge wprb8050d...everything seems to work ok except it would not spin during spin cycle. moved it to...
(More)
GE WPRB8050D...Everything seems to work OK except it would not spin during spin cycle. Moved it to look for the model #, now it spins again. What gives?
Machine will fill with water, but then will not go into wash cycle. Also, will not go into the drain...
(More)
Machine will fill with water, but then will not go into wash cycle. Also, will not go into the drain and spin cycle . Here a click noise comming from the top panel, like it is trying to switch into a cycle.
