Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Error tone I recently had my HD plugged into a power strip, there was a power surge and now when I apply power to the HD, or connect it to the laptop, I get three error tones and the HD is not recognized. It is getting power and that is about it.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
While it is connected to the system try to unplug the USB cable and then reconnect it.
also try to update the USB drivers.
Posted on Jan 07, 2008
Power surge, nothing working
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 10, 2013 | Acer Ferrari Computers & Internet
Error 935,10 service printhead error. e450dn
The printhead is the laser, tou have an error in the laser assembly (replace the laser assy).
Feb 23, 2011 | Lexmark E450dn Laser Printer
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Will not boot give error code one long beep tone 2 short no screen no HD or display Tone will not happen if Memory is out . HD is not powering up not backlight to screen no fan sound this is a Toshiba...
Without knowing which bios chip is in the machine this will be quite difficult. One long and 2 short beeps, with some bios chips, means faulty graphics controller chip.
Jun 06, 2009 | Computers & Internet
Battery Backup/Surge Protector Question
Considering the low draw of power you intend for the UPS it will work well. I have two monitors on a strip plugged into UPS along with desktop, routers and modems, UPS handles all well, it's just shortens battery backup times. Have had to power down from outages several times without any probs.
Jan 30, 2009 | APC Back-UPS RS Battery Backup (apw...
Presario 2200 won't turn on after local power outage
Hi Mellisa,
If there isn't any lights on the laptop when it is plugged into the mains supply there is a power problem.
Check the surge protector, has got a reset button?
Plug a lamp into this surge board, if the lamp lights up when the board is connected to the mains then the surge board is OK.
Next check the laptop's power adapter with a multimeter, the voltage reading should be as per the label on the adapter. If the voltage is less than the voltage on the label, then it is faulty and needs to be replaced.
Borrow another adapter to connect to your laptop to see if it powers up or take it to your friendly computer shop to test it.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
HP 6110 error message "clear carriage jam"
No one from "FixYa" provided me any useful solutions to try. Following the HP reset instructions many cycles did not work. By accident, I finally got the HP 6110 working again by unplugging it from the Monster brand surge protector power strip, depowering both for a period of about one hour, then repowering the power strip, then plugging in the HP 6110 and going through its reset function once more. Plugging the HP 6110 directly into the wall outlet into which the power strip was/is plugged did not solve the problem. Note that gremlins in that same power strip also adversely affected my ZyXel DSL modem, or perhaps spurious backfeed signals from that DSL modem affected the HP unit. Sorry, I'm not able to provided any explanations as to why this worked; I am not a digital/PC'electronics person. I was about to tear the machine apart to clean all the surfaces and mirrors as others had recommended, or buy a replacement.
Dave R.
Dec 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
My Laserjet 1018 will not start
Can you please describe your problem?
Jul 12, 2008 | HP Office Equipment & Supplies
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
65 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
