Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
I hear the xbox 360 sound but no visual pictures
By dedria_xyooj on Nov 11, 2009
I hear the xbox 360 sound but no visual pictures. it says invalid format
Solution #1
posted on Nov 11, 2009
Not Rated)
XboxRepKit
Rank: Guru  Microsoft Expert
Rating: 93%, 32 votes
Is the light on the power supply? if so is it red, green or amber? this can help. If its red it could be either
the power supply which is faulty or a major problem with the 360 which is causing a short or something
similar. What is probably wrong witht he 360 is the 3rrod:
When the Xbox 360 overheats it causes the lead free solder to crack, the more that crack the worse the
machine will get. So eventually I suspect your machine will die completely and show either 3rrod or e74.
To remedy this you need to strip the console down and replace what's called the X-Clamps, at the same
time replace the heat-sink paste and then you need to re-heat the whole board. We use a special IR over
which re-bakes everything and re-seats the solder properly, a lot of people use a heat-gun but you have
to be very careful.
Linda
Was this helpful?
Yes
No
Solution #2
Not Rated)
nickbosch
Rank: Guide
Rating: 0%, 0 votes
turn the switch on the video input plug that connects to your system from HDTV to TV or vice versa. On a NON HD tv you also don't have to plug the blue,green,and extra red input plug into the tv, just the red,white,and yellow.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
my xbox 360 has one red light. how can i fix this
Answer
Whilst playing a game, the colour changed to a pinky colour. I switched the console off and there is... (More)
Answer
when unplugged and then replugged in the console will not turn on but the fan runs constantly... (More)
Answer
i unplugged the xbox, turned it on and it wont start up. the power plug has an orange lite on
Answer
No video or audio, bought a new AV cable still doesn't work
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 416
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
