Question about Creek 5350SE Amplifier
Annoying hum Just hooked up my LCD tv, dvd player, digital cable box, PS3 and Cd player to my Onkyo Pre and am getting a humming sound thru my speakers...I'm not at all technical...so please speak simply. Thanks
    Scholar:
  • 70 Answers
The first answer was a correct one as a first/last resort. In other words if any of your devices are three pronged and your using a 3 prong to 2 prong adapter-DON'T.
In my experience as a sound engineer (30+) years, a hum is caused by a "ground loop". This is caused by one of 2 reasons. There are 2 true earth grounds or a cable is broken. Since you are at home (and I'm taking it for granted it is a newer house/apartment), there will be one true earth ground. By the way- a true eart ground is when A 10 foot pole (ground rod) is sunk in the ground and is attached to the ground terminal at the outside breaker box. You can easily check this by going outside and look for a single wire that is clamped to the ground rod. If you are in an old house where there is only two pronged outlets you will have to do your own ground. Ask another question for that and I'll send detailed instructions for creating your own true earthground
Which means it is a cable. The most common device to cause a g. loop is one that records also. Power down the receiver, take the cable for the cd off (from the receiver), turn on, see if hum. Go through each set until you isolate the cable that is bad.
Hope this helps.
Jeff
Posted on Jan 08, 2008
    Scholar:
  • 103 Answers
Something else to consider is that you should keep all your mains wiring as far away from your audio wiring as possible, and never coil any mains cable around when in use. Once everything is installed & in place, some cable ties will help you achieve this.
The positioning of your speakers may also be causing this problem if they are very close to any electronics.
    Problem Solver:
  • 6 Answers
First of all touch the metallic body of the amp with your palm after removing your footwear and find out if there is a reduction of the hum sound. If the hum is reduced that means there is no proper earthing .Check whether the power supply is properly earthed.If there is no earth connection in your home wiring there will be hum.You can ask your electrician to solve this problem and then switch on the system.
If the problem persisits check the audio cable for any damage and replace the cable with a new one.
Sometimes the hum may be caused by a tubelight which is taking power from the same plugpoint you are using for your player.this can also cause noise.
Hum from tv
try unplugging any equipment that you have attached to the tv one at a time, such as dvd players, surround sound, cable box, etc. also if you have a cable box attached, try adjusting the volume on it. if you have everything unplugged from tv and it still hums, then it may be a tv issue
Oct 21, 2009 | Televison & Video
My lcd tv makes a humming noise
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Mar 14, 2009 | LG 42LG30 42 in. LCD HDTV
Humming sound on cable setting
have you tried to input another audio source into the audio inputs on the reciever that the cable box outputs are going into on the reciever ?
you may also need to ground the recievers frame and cable box frame to earth ground.
you also may have a bad connection in the wires or jacks for the audio connections
or the cable box audio out circuit needs repair
Feb 04, 2009 | Onkyo TX-SR606 Receiver
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Tv hums when hdmi is connected via dvd player
how do you have the audio hooked up for it if you are using componet cable (red,white) for sound they could be causing the humming you can either switch audio cables or use some other form of cable for sound
Jan 24, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
Humming noise while watching DVD on Harmon Kardan DVD 5
if the humming sound is in the tv or sound system you will have to check wiring connections and ground wires.
If the humming comes from the dvd player clean optical head with a dvd lens cleaner disk
Oct 04, 2008 | Televison & Video
I've just purchased my ps3 i've hooked it up using component cable and i get a annoying humming tone from my t.v. also i've noticed a purple line going up the screen. Can you please help me
The problem is that my tv cable is not properly grounded which causes the the humming sound. I just unhook my cable when I start to play.
Jul 05, 2008 | Video Game Consoles & Games
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
317 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
