Nov 12, 2009
- Below is the manual for the CQ50, this will show you where the RTC battery is so you can unplug it.....The below entry was copied from the manual on page 46, it is the cmos and password reset by removing the cmos battery for over 5 minutes and reinstalling. Follow along below.
RTC battery
NOTE: Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all
passwords and CMOS settings to be cleared.
Description Spare part number
RTC battery 486624-001
Before removing the RTC battery, follow these steps:
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery (see Battery on page 40).
5. Remove the hard drive cover (see Hard drive on page 43).
Remove the RTC battery:
1. Disconnect the RTC battery cable
(1) from the system board.
2. Remove the RTC battery
(2) from the clip built into the base enclosure.
Reverse this procedure to install the RTC battery.
46 Chapter
http://h10032.www1.hp.com/ctg/Manual/c01572022.pdf
