Question about IBM ThinkVision L170 17" LCD Monitor
How to unlock the screen menu
I have a IBM ThinkVision 17" LCD screen. I'm not able to change the screen setting. Whenever I press any of the buttons other than the Brightness Adjustment button, I see a message which says ' Menu is Locked'
Please let me know how can I correct this.
Regards,
Shibu
  • ourforce Apr 25, 2009
    I have the same problem! I have press the button for 10 seconds, and it confirms that the menu is unlock, and yet when I go into the menu it still say locked in "image properties". What is it acting this way?
    Thanks
  • 81 Answers
You need to press and hold the "enter" button for 10 seconds to unlock the controls for adjustment. After you have the settings where you want them you can press and hold the "enter" button again for 10 seconds to lock menuback up. This will prevent anyone from changing your settings by accident.
Posted on Jan 08, 2008
  • Asif Khan
    Asif Khan Aug 28, 2016
    Thank you for suggestion
    New Friend:
It's now working properly. Thank you for suggestion.
Thanks
Robert
Posted on Feb 22, 2013
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Im getting horizontal lines that filling screen fully from top to the bottom
Press the Menu button on the Monitor, if the lines go over the monitor then its a Fault with the Monitor.
If the lines go under the menu then its something with the computer. e.g. graphics card. Try pressing F8 when you first turn the computer and go into Safe mode and see if you get the lines on the screen. If you do its a Hardware problem with the graphics card. If you don't its a software problem update the graphics driver.
Apr 25, 2011 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision monitor problem
I would try it with other PC, if it is still doing the same thing and you want to DIY repair, then please read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | IBM ThinkVision L170 17" LCD Monitor
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
UNABLE TO ADJUST THE SCREEN ALWAYS SHOWING MENU LOCKED
When you press power button press continues F8 key then you see safe mode and other menu enter in "ENABLE VGA MODE'
then go to dispaly property and settings then change screen resolution to 1024.768
then apply and ok.
Aug 18, 2009 | Lenovo ThinkVision L151p (Black) 15 inch...
IBM THINKPAD
Hi...there,
It's seems your Thinkpad need a new inverter, due to a backlight inverter burnt out. Get a new one or repaired it. Good lucks!
Sep 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision l170 monitor
Hi! Tammy,
It's seems your new pc resolution settings, set to high...
Hook up to another monitor and go to settings to correct your
resolution to 1280x768 or less. That will fixed your problems.
Good lucks!
Aug 07, 2008 | IBM ThinkVision L170 17" LCD Monitor
How to reset to factory default - to solve blurred text problem
Press the OSD enter button and scroll down to options. Factory reset is in the options sub-menu.
Dec 13, 2007 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
5,729 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
