Question about Toshiba Satellite A35-S159 Notebook
Will not power up
I have a A35-S159 that will not power on with or with AC power cord or battery.. When AC power cord plugged in, the led lights for the AC and battery are both green. Once I hit the Power button, PC tries to start for about 1-3 seconds, then immediately stops and the LED lights go out.. These LED lights will not come back on until I unplug the AC cord and reconnect.. I've already taken the heatsink out and cleaned. Not sure what's the problem here???? Anybody out there with similar problem that could provide some assistance???
  • BigDawg1 Jan 07, 2008
    Thanks for the post reply.. First option did not work.. I will try to find a battery to see if this will solve my problem.. Any other ideas.. My last option is to replace the motherboard..I hoping to find a resolution before going to this extreme measure...
    Sergeant:
    Champion:
  • 310 Answers
Pull battery and cord. push on / off button for 60 sec. put battery back in and plugg in power and boot up.. something else to try is some one elses battery to boot up in.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
2 Suggested Answers
SOURCE:
kornho
  • 781 Answers
SOURCE: Toshiba satellite A35-S159 Microphone
please answer the following questions and follow instructions accordinlgy:
1. did it ever work? what changed since?, if something change try to use system restore to go back to the time prior the changes
2. did you just installed the chat application? skype?msn messenger? yahoo messenger? if you just install the application where you are trying to use the mic. you need to configure your mic before you can use it. usually under tools or settings you will find sound devices, some computer may have more than one source of input sound (mic) so go into those settings and look for a way to set your mic as the source and test to ensure it is working. the configuration procedures may differ among applications.
3. did it work and stop working all of a sudden and system restore won't get it working again?? you may have a driver issue, first try to reinstall the driver for that you need to do into device manager, found the sound devices, select the device with a yellow ? or ! and attempt to uninstall the driver, then restart your computer, the driver will reinstall by itself, then go into the chat application and reconfigure your input device and test.
on some ocations you may have to look for a new driver to solve your problem for that you need to go into the manufacturer's website, look the model of your number up and look for the a possible new update for your sound device driver and installed as per manufacturer's instructions. find the drivers need for your system here
provide more details as noted above and if possible we will try to assist further.
Posted on Mar 27, 2010
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
My Toshiba Satelite a35-s159 can not connect to the internet unless its plugged into the wireless router or the modem
I had the same issue with the one I had. It was kind of a problem getting the WIFI to turn on. Consult your user manual or a quick google search to get the directions on how to turn on your WIFI. I don't remember if it has a switch on the front or not.
May 03, 2011 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35 S159 AC PROBLEM Can a laptop run just on the ac without the battery? I just watched a video on youtube and the guy said if you want to save your battery you can take it out and run on...
Yet you need to set up what is called a hardware profile so that you can use the Laptop on either AC power only or on AC Power and Battery. Although it is normally used for docking it can still be used for the battery.
One profile for the office where the laptop is docked and the network adapter enabled, and a second profile can be created for use when you are working away from the office that disables the network adapter but enables the modem.
To set up hardware profiles in XP, complete the following steps:
  1. On the desktop, right click the My Computer icon and select Properties.
  2. From the Hardware tab, click the Hardware Profile button.
  3. Under the list of available hardware profile, select Docked Profile or Undocked Profile and click Copy.
  4. Type in a new name for the profile and Click OK.
  5. Select the new profile and click Properties. Select the check box beside This is a portable computer. Select the docking state for the profile. Click the option to Always include this profile when Windows starts. Click OK.
  6. You can now use Device Manager to enable and disable devices for a hardware profile.
Some people do say that if you totally discharge a rechargeable battery and then fully recharge it you will get a greater AmpHour from it but this will be negligible as all batteries have a standard number of Amps that it will deliver built into it, it may fall with age. Although rechargeable batteries don't just fail like normal dry cells they tend to fail over a period of time and fool us a bit.
LOL
Sep 28, 2009 | Toshiba Satellite A35-S1592 Notebook
Toshiba A35 S159
you forgot the most important item in the whole equation the battery.How long will the computer stay on with the battery?One quick fix,try using a toothbruch to clean the contact on the battery and on the computer.This might work.I think the computer is fine. The battery might be bad,
Sep 28, 2009 | Toshiba Satellite A35-S159 Notebook
I need to install drivers for a35-s159.The Toshiba support page no longer supports this model.I need the modem and Ethernet drivers according to my hardware mngr
Wow, I can't believe they removed it from their support page. bummer.
You can try a simple Windows Update.
It should detect the missing drivers.
Let me know if it doesn't.
Jun 15, 2009 | Toshiba Satellite A35-S159 Notebook
Lcd toshiba A35-s159
your correct the lcd inverter or the lappy lcd bulb is shot
ebay toshiba satellite a35 lcd inverter buy that link me
[email protected] i walk you you need a screw driver
Apr 12, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S159 Notebook Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
