Question about Sharp AL 1215 Black and White Copier
HELLO SHAH JI
SHAH SAHIB Meray pass Sharp SF-118 Photocopier way
Jab main ON karna Wa Te C H Flashing Error Anda wa
What should i do
  • Sharp Master
  • 1,113 Answers
Check All the doors are not ajar/open ! Make sure they all close smoothly and properly.
Maybe door switch is bent
Posted on Jan 07, 2008
I am put fan and processor gum wa not
Dear,
you need to get a compound called heat resistive compound for this. Otherwise your processor will be heated a lot and will cause restarting of pc after heating...
best of luck!
Mar 07, 2012 | Biostar G31-M7 TE Motherboard
I have a sharp sf 7500 photocopier and it is showing code U1 and will not work, what is the problem please
U1 : main board battery low voltage ,you can reset the code by Sim 13 if it didn't work replace the battery .
Jan 18, 2011 | Sharp Office Equipment & Supplies
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
My black and white sharp photocopier mdel sf 2530 is showing h5 what is the meaning of this fault and how do i clear this fault
Hello sir; To reset H5 ,you have turn power on then open front door, press and hold exposure key while you closing front door.
Oct 06, 2009 | Sharp Office Equipment & Supplies
Sharp Photocopie SF 2035- warm up problem
Dose the copier show a error code? Like a H4??? If so you have a problem with the fixing unit. I do belive it can be reset, but the problem needs to be repaired aswell.
Jul 26, 2008 | Office Equipment & Supplies
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
Sharp AL 1215 Black and White Copier Logo
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
