Question about Pioneer CDX-P670 6-Disc CD Changer
Cdx-620s willnot power up
Should the small white plug have power to the middle terminal
  • 78 Answers
No there's just one 12v positive and a negative on the white plug, these units were prone to dry joints on the power supply board so if you strip the unit down and unscrew the power supply board which is screwed to the chasis and look around the white plug connector and also the bus lead connector beside it, you may find that it needs resoldering, hope this helps you!
Posted on Jan 08, 2008
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
Tell me how to reset the cd player on model # cdx-gt420ip. I can't download the manual on my computer.
pop out the front of the stereo and there's a small reset button around the middle of the part that's still attached. get something somewhat sharp like a pencil to press it with. that should reset everything but if it doesn't work you can take the whole thing out and disconnect the wiring harness and wait about a minute. then plug it back in and put everything back. that will reset everything too.
Sep 12, 2010 | Sony CDX-GT420IP CD Player
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Find remote wire connection for sony cdx ca400
Should be a blue wire with a white stripe in the plug that goes into your unit if its missing take the harness to bestbuy or an audio shop and they can prolly stick a wire in the empty spot. hope this helps you.
Sep 16, 2009 | Sony CDX-CA400 CD Player
3 prong to 4 prong where do you go with the ground wires
The following link explains how to correctly install a power cord on your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link thoroughly and let me know if you have any questions. I hope you find this helpful.
Jul 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How to connect wires on plug on dryer
3 wire plug,middle wires goes to middle terminal,each of the other 2 wires goes 1 on each side,does not matter which one but the middle wire must go on middle terminal,4 wire plug-the white wires goes to the middle terminal,the red goes to red and the black goes to black,the green wire must be mounted the the case-mike
Jun 28, 2009 | GE DVLR223 Dryers
I want to replace just the 3 wire receptacle head of my clothes dryer. there are three wires in the cord. white, black, green. i unscrewed the head and I dont know where which wire goes.
white and black are power green is ground the ground should be marked on the plug the black and white does not matter as long as the are on the power terminals they are across from each other the ground is by itself at bottom of plug W B
G
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Eric
Jun 08, 2009 | Electrolux Dryers
Electrical plug is not attatched
3 wire setup, middle wire goes on the middle of terminal block,and one wire each on each side of it,4 wire setup white wire goes to middle of terminal block ,red and black goes to does not matter which side(both 120 volts) goes on each side of block,the green wire gets mounted to the cabinet,it is the extra ground-mike
Mar 09, 2009 | Kenmore Dryers
Loose front AUX
The wires on the plug. Red, goes to the R terminal. Black goes to the one marked G. And the White goes to L.
Red - R
Black- G
White-L
Mar 21, 2008 | Sony CDX-GT100 CD Player
Pioneer CDX-P670 6-Disc CD Changer Logo
135 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
