Question about Paradyne COMSPHERE 3910 Modem
Paradyne 3920 LL modem
I've got a apir of 3920 modems which has to be used to setup a LL connection to a remote branch. The ISP is giving a 2 wire connection.
when I connect these modems back to back with the grey cable which comes along with the modem, it works fine ( it is a straingth cable), but whe i use just 2 wires to connect it the modem shows the alarm indicator and is in training mode. I tried with 1> 2 , 2 > 1 and also with 1 > 1 and 2 > 2 options, but it doesnt work. I've configured the modem for 2 wire operatoin.
Could you please help me to know how to get it working back to back using the 2 wire option ?
  • Anonymous Apr 21, 2008
    HI.i want to connect to 2920 modem back to back by leased line connecting
    what configrations I must set.
    tanks my email
4 Suggested Answers
SOURCE: configuring paradyne 6211 adsl2
ayamaya is says correctly.
Posted on Nov 21, 2008
  • 82 Answers
SOURCE: driver Paradyne 6205 aDSL Modem 6205-A1-000 for win 7
if you can see a vista driver downloadable from the manufacturer's site, it will work 80% of the time.
Posted on Nov 06, 2009
  • 12 Answers
SOURCE: I accidently knocked over my roommate's modem and
Sounds like it became un-soldered from the motherboard.
Posted on Mar 17, 2010
My company provided me wired internet using Paradyne 6381 wired modem. it works fine. I have D Link 2640 T wirelss modem + router available with me. Please advise me how do I connect available D link 2640...
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be or
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
Oct 23, 2017 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Electrician disconnected the paradyne imarc didn't label cabels
Go to this link and download the manual. It has everything.
Please rate the answer if it helps you
Good Luck
Jun 22, 2009 | Paradyne iMarc 9123 Branch Office Router...
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Router administration access
Hi Neomonkey,
It seems like you have a very big problem. If you are successfully connnected to the wireless router, you can check the the ip address of the router by doing an ipconfig in command prompt, check the default gateway and try to access using IE browser. The next problem is accessing the router when you are prompted to enter the username and password, the default is username: admin password: admin, depending on the model, if it is customized, you will have to reset the router to access it and configure the mac filtering or enable wireless security to deny the person who is taking up your bandwidth. You dont have to access the Paradyne modem to configure everything, if you want to find out if it is running DHCP, you can connect a PC wired(straight UTP cable) with all the network settings at default and check if you can get an ip using ipconfig with the command prompt. The main thing here is to reset your wireless routers to factory defaults(use the button at the back) to re-organize your connection and setup a security for unwanted users.
Inform me if there are other questions or clarifications you need regarding the problem.
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Dialup link problem
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 02, 2008 | Paradyne COMSPHERE 3910 Modem
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Paradyne Dsl Modem
Hi, If I understand you right, what you want is to use your Paradyne 6211 modem to share the Internet connection to 2 PCs. One is connected through the USB and the second through Ethernet port. Tried it on a Siemens 4200 and a Prolink Hurricane 9000, both worked and can be done. To be sure, the IP settings of the PC connected via Ethernet was set to manual configuration. In your case try IP, Subnet Mask, Default Gateway, DNS Servers - whatever your ISP are using. You of course can try and see if it works in your modem. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 03, 2007 | Paradyne (6211-A2-200) Router
Paradyne Vista Compatibility
as far as i think your system has not install modem as your isp line support so frist install the modem which your isp line needed go control penal >phon and modem >add modem from the list and apply ok
Sep 01, 2007 | Computers & Internet
Paradyne COMSPHERE 3910 Modem Logo
216 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
