Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Brushes not turning
I have two, one less than 3 months of use, that no longer work because the brushes won't turn. It seems like a problem with a seal somewhere. Filter is clean, everything seems to be as it should be.
    President:
  • 1,673 Answers
Check the belts, there ia cogged belt that drives the brush roll. Turn the unit over, take out the one screw holding the red lock, pull that off then the cap for the brush roll will pull out, remove the cap and check the belt, also check the pulley on the end of the pump to make sure that it still has cogs on. If there are no cogs, then you will have to replace the pump. While you have the brush roll out, make sure the it looks ok on the end and not melted. This would also be a good time to replace the **** belt if it needs it.
Posted on Jan 08, 2008
Bissell proheat 2x troubleshooting
Hi, it's Allie from Crucial Vacuum!
There are several things that may cause this to happen in your Bissell ProHeat 2x, like the brush assembly or the belts.
First, make sure the cleaner is reclined, or the brushes will not turn. If your unit is reclined and the brushes still do not run, check if there is anything tangled in your unit's brushes or if the brushes are damaged. Clear the brushes of any hair strands or tangled debris for their optimum performance. We recommend for these brushes to be cleaned and checked monthly and replaced once a year.
Next, unplug your unit and check both of your units belts. It is recommended for belts to be changed every 3 to 6 months, depending on the use of your unit. Belts can be stretched out and loose, causing the brushes not to spin properly.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 15, 2014 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Brushes aren't turning. switch is on
Remember that the brushes turn best when the handle is tipped back. If this does not work, remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush usually fits into. Try to turn the fitting. If it won't turn, the air driven turbine has seized up and will require replacement.
Jul 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes o longer turn in my roomba
Try removing brushes, cleaning thoroughly removing yellow tips if there is any and removing hairs, re install brushes and turn manually about 20 turns and re try
Aug 19, 2010 | iRobot 4150 Roomba Vacuum
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Brushes won't turn
Look at the ends of your brushes were the brush piece attaches to the vacuum. Sometimes they are broken or just stuck. good luck
Dec 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
222 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
