Question about Sharp AR-207 Copier
Sharp SF-1118 copying machine CH FLASHING
I have SHARP SF- 1118 Photocopier when i turn on then give CH flashing on LED
What should i do?
Mechanic code number
Posted on Feb 12, 2008
  • seekajanthy Feb 12, 2008
    Mechanic service code number for sf1118
H4 error
Posted on Oct 22, 2012
  • Sharp Master
  • 1,113 Answers
CHeck all the doors and door switchs, attachments are closed/engaged correctly. Possible faulty/bent switch.
Posted on Jan 07, 2008
Please .. my Photocopier sudunly stop and find
My Sharp is a different model but my reset is:
Hit:
Clear (then)
Auto (then)
Clear (then)
Auto (then)
14 THEN
Start
It resets itself.
Oct 06, 2009 | Sharp AR-207 Copier
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
Error CH uppon power up...copy lamp comes on scaner moves forward 2...3 inches shakes and machine stops...
OK, CH normally means the one of the covers(front or side panels) is open or the developer unit is unplugged try these to see if that fixes the problem. p.s When the covers are closed a small tab on the covers triger a interlock switch or optical switch. Hope this helps
Aug 22, 2007 | Sharp AR-160 Copier
Red man flashing on photocopier
Hi Your Copier needs a service, that is what that led is for Hope this helps Regards
Aug 08, 2007 | Sharp AL 1215 Black and White Copier
Sf-1118
does the same occur when the manual paper feed path is used?
Apr 08, 2007 | Sharp AL 1215 Black and White Copier
Sharp AR-207 Copier Logo
1,576 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
