i have a rolex yachtmaster 2 the min hand stays @ 4 however when i press the rest button starts wrkng fine again till it reahes 4 again what can i do to resolve?
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
Good evening, I have been using my Timex with bodylink monitor system for more than one year....
(More)
Good evening, I have been using my Timex with bodylink monitor system for more than one year. Yesterday, the Indiglo (not the button itself) screenlight stopped work. When I press the Indiglo button, there is no light. I tested also the "night mode" (you press any button and the screen should light on), but neither did it work. My Timex did not drop aground or was damaged otherwise. I have also changed the battery, but no change. Maybe I have pressed some button and stopped it to work (?) Any idea how can I fix this ? Thanks. Kristina
wva-470de-2avef. I have the above watch and for about two weeks now the analogue second hand and the...
(More)
wva-470de-2avef. I have the above watch and for about two weeks now the analogue second hand and the seconds on the digital display have been out of sync by about 2 seconds - How can I resolve this issue
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and...
(More)
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and they can't figure it out.
