Question about Buffalo Technology HD-HG400LAN (HDHG400LAN) 400 GB Network Storage Link
Cannot Access Shares
I turned the unit off while on a short vacation and when I turned it back on, neither laptop or desktop can access my shares. The desktop doesn't see anything through the NAS client utility, but the laptop does. Even though it can see it, it still says that the drive isn't attached to the network when clicking on view shares.
Any ideas on how to hook it back to my network?? Any help with GREATLY be appreciated!!
  • mdubois Jan 07, 2008
    Thanks for getting back so fast!
    My accounts on both machines are set as the admin, do I still need to do this? If yes, could you give a little more instruction as I cannot find where to get it to ask for sign in information.
    I am running Vista Home Prem on the laptop and XP Home on the desktop.
    Thank you!!
    Genius:
  • 1,226 Answers
Log on the computer to "administrator" account both system will see each other. To do this:
when computer prompted to type your password , Simultaneously press" Ctrl+Alt+Delete" 2 times and you'll prompted to type the username: Just type "administrator" and then enter(note: applicable if the the administrator username has no password.)
any problem regarding the solution please notify me for further information.
Posted on Jan 07, 2008
6ya staff
SOURCE:
I wish to liquidate usa share certificates who will do it
A stockbroker can handle this but only if a buyer can be found. Otherwise, they will have to be declared a loss.
Nov 06, 2013 | Computers & Internet
Tip
Access to the NAS-T2 from Linux
Quick tip: when accessing the NAS-T2 from Linux, mount any NAS-T2 shares using smbfs, not cifs.
More detail: This tip presumes you're familiar with mounting filesystems in Linux and are trying to mount an NAS-T2 share in Linux. The older smbfs filesystem type for mounting Windows shares is deprecated in favor of the newer cifs filesystem type. However, the NAS-T2 is built on some older flavor of Windows and behaves very oddly when mounted as a cifs filesystem. Changing back to the older smbfs filesystem type solved all my problems.
on Jan 13, 2008 | Fastora 2 Bays Network Attach Storage...
Networking please guyz how can i share files, printer and scaner between two PC runing window xp (service pack 2) using lan protocol
Turn on File and Print sharing. You will see a hand sharing icon on printers. You then need to create shares for individual folders you want to share by right clicking on folder. Then use the share name to access. Example: \\computer_name\share_name
Oct 24, 2012 | Computers & Internet
How to use antilog by casio fx-82es
The inverse of the log function is the function 10^
antilogarithm of (x)=10^(x)
The function shares the same physical key as the [LOG] function. To access it you press [SHIFT][LOG].
The antilogarithm of the natural log [LN] is the exponential function [e^x]. It shares the same physical key with the [LN] function. To access it press [SHIFT][LN]
Aug 29, 2010 | Casio FX-300MS Calculator
How to antilog with TI-84 PLUS
The antilogarithm of natural log [LN] is the exponential [e^x]. It shares the same physical key as [LN] : To access it press [SHIFT][LN]
The antilogarith of the common logarithm (LOG] is [10^x]. It shares the same physical key as the [LOG]: To access it press [SHIFT][LOG]
Aug 28, 2010 | Texas Instruments TI-84 Plus Calculator
Wifi server
Once you have setup the central sever you can right click either the harddrive(s) or individual folders and there should be an option to share (or sharing and security). Open that and it should be quite straightforward to setup permissions so all computers can access those network places.
Next on the server right click My Computer and click properties. Write down what the workgroup name is.
Now go to the Vista laptops and goto Control Panel, then network places, or view wireless devices on network. Hopefully your shares will appear on the laptops and you can access them.
If they appear and you canot access them then you probably need to go back to step one and alter the permissions for sharing on the XP server.
Hope this helps, www.PuterCare.com
Apr 09, 2010 | Acer Aspire 5050 Notebook
Disable network access to registry!!
are you running winxp os? if so go to control panel click on administrative tools then on services, look down the list until you see what your looking for and disable it. I hope this helps.
Feb 08, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Access denied to network to laptop
Disable all firewalls, both on laptop and on computer that shares the printer.
Ensure that laptop and desktop sharing the printer are both on same Domain or Workgroup.
If this does not fix it, call back the Geeks and thell them to acces the router configuration, and configure router internal firewall.
Put both laptop IP and computer sharing printer IP in the range of thrusted IP on router settings.
Sep 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Can't Access Public Shares via NFS
You can mount the shares something like this:
mount -t cifs -o username=backup,password=YoUrPaSS //192.168.0.145/projects /mnt/nas/projects/
...where 192.168.0.145 is IP of SS4000-E and /projects is the shares folder
and /mnt/nas/projects/ is folder you have created on your Linux box
Hope this helps
Best Regards
ashley
Apr 11, 2008 | Intel SS4000-E (SS4000ENA)
N/w problem
Dear AJINKYA11,
To access the administrative shares of a Vista computer from another computer, you will need to change a registry setting. You will need to change HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\syste m\LocalAccountTokenFilterPolicy to 1 (DWORD).
To do this:
- Click start
- Type: Regedit
- Press Enter
- Browse to:
- Right-click a white area in the right pane
- Click New
- Click Dword Value
- Type: LocalAccountTokenFilterPolicy
- Press Enter
- Double-click LocalAccountTokenFilterPolicy
- Type: 1
- Press enter
- Restart your computer
You should now be able to connect to the remote administrative shares on
your vista computer by authenticating with an account that is an
administrator.
cheerup
Mar 05, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Open Questions:
BroTheR PrinTeR CusTomeR SeRviCe pHoNe#{@+1~888~589~0410}nUmBeR Texas USA Brother Printer Customer Service [email protected]+1~888~589~0410 Texas USA Brother Printer SuPpoRT Number Brother Printer SuPpoRT phone Number Brother Printer TeCh SuPpoRT Number to resolve all Brother Printer products. Brother Printer is an American multinational company which was founded by Michael Brother Printer using its company headquarters in Round Rock, United States of America. Contact Brother Printer for Setup & Installation Brother Printer Setup Free & Installation Brother Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Brother Printer Connect setup for Windows and for Mac. So, right here we go VIKKI. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Brother Printer Connect, Brother Printer TECH Free Phone Number you'll be searching out Brother Printer Connect setup as well. So, here we're with all cthe setup process and for your to Brother Printer Connect. Get Brother Printer Setup Instant Free Brother Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again.
Nov 12, 2019 | Brother Computers & Internet
AOL MAil SuPPoRt NuMbER [+]{1+/855+/536+/5666-} FLORIDA $%^^}#[email protected] call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 12, 2019 | AOL Computers & Internet
See all Buffalo Technology HD-HG400LAN (HDHG400LAN) 400 GB Questions
Buffalo Technology HD-HG400LAN (HDHG400LAN) 400 GB Network Storage Link Logo
182 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Ekse
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
