Garmin Rino 120 2-Way Radio
Problem for Garmin Rino 120 2-Way Radio
Rino 120 speaker no longer worked after using headset jack.
By luckydogsurf on Nov 11, 2009
I bought a headset for my Rino 120. Once I plugged it in (then removed the plug) the speaker never worked again. It seems the speaker-disable pin on the headphone jack has been bent. I tried to disassemble it (removed obvious screws) but it won't come apart. Is there a trick for removing the cover. I'd like to bend the speaker cut-off switch/pin back so that I can use the unit again. Everything else works fine.
Popular Solutions for Garmin Rino 120 2-Way Radio
Questions and Unsolved Problems for Garmin Rino 120 2-Way Radio
Do you recommend Garmin Rino 120 2-Way Radio?
Answer
Answer
I loaded topo maps to the rino 120... if I am in a metro area can they be viewed?
Answer
My friends and I bought Rhino 120's 4 years ago and theres locate on the higher freequences and mine... (More)
Answer
Rino 120 will not turn on, checked batteries all oka, still will not turn on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Garmin Rino 120 2-Way Radio:
Top 2 Way Radio Experts
Rank: Guru Guru
Solutions: 563
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more 2 Way Radio Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
