Question about iLO (2 GB) MP3 Player
Usb flash dish
I cannot play and neither can i delete the items in my usb flash dish it says it is write protected, when there are no switch or button to use to make it write protect. how can i solve this problem?, i cannot use my usb flash dist now.
  • medlockv Jul 24, 2008
    i can not delete any song off my mp3 players. i don't have the information to do it.
How to change file system for the flash system
Posted on Jul 24, 2008
    Problem Solver:
  • 6 Answers
Problem is not with your player but with your computer
do these steps to avoid problem :-
1) open note pad
2) type following into it
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies]
"WriteProtect"=dword:00000000
3) save it as .reg extension
4) make sure extension of file is .reg ( once it in done then note pad icon will change)
5) double click on this icon
this should solve your problem
Posted on Jan 07, 2008
Write protected PNY 4GB USB
Go to Start
Click Right mouse button on Computer
Click on Manage
Click on Disk Management
In the Right Panel of the drive you wish to fix
Click Delete Volume
When Volume is deleted
Click Create Volume
Follow the steps
For small drives use Fat32 not NTFS
NTFS is not portable between XP and Win 7
You may also have a virus.
Mar 27, 2014 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My flash dik is write protected
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My sd card on my camera now says write protected...
Look for a small switch on the side. Switch away from the locked position.
May 20, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
Delete write-protected file from usb
some... not all have a tiny switch on the side... move that to the other position and you should be abel to delete it. if that doesn't work... download a program called unlocker from
http://ccollomb.free.fr/unlocker/
Mar 21, 2009 | Electronics - Others
Cannot remove write protection on sandisk cruzer usb pen.
The memory cards also have a write protection switch to protect data from being deleted or overwritten, just like a floppy disk
Dec 03, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
iLO (2 GB) MP3 Player Logo
35 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
