Question about HP Deskjet D2360 InkJet Printer
No power power adaptor good condition but still no power when pressing the power button
  • HP Master
  • 1,113 Answers
Usually it is Power supply / main board is stuffed, too expensive a fix if not under warranty, Required fix if power supply is known to be delivering power to the machine is Replace main board.
YOu could check that connector socket is not loose but chances are the boards have had a power surge or they are ink corroded
Posted on Jan 07, 2008
6ya staff
SOURCE:
AC Power Adaptor LED won't stay on to power PC
First you you should test the AC power adaptor properly, then if it is in good conditions is important to test the electric circuit in the motherboard in order to find any trouble. There is a SMD fuse between de DC power jack and the rest of the circuit.
Jan 06, 2014 | Computers & Internet
Tip
Laptop has no video but ower LED is on and restarting system does not help!
possibly the safety system kicking in
step #1: remove the battery and all other external hardware
step #2: disconnect the power adaptor
step #3: press and hold the power button for 10-20 seconds
step #4: connect the power adaptor only! no battery!
step #5: press the power button to start system.
spet #6; If the system boots and you have video let it boot and run for 10 miniutes ... then shut down and reconnect the battery....
step #7: reboot system If system is still good repeat step#6
continue this process until all hardware is reconnected.....
This is very common among all laptops especially if they are connected to the adaptor for very long periods of time without using the battery. The process of holding the powerbutton with no energy to the laptop drains the power out of all of the capacitors on the system board and thus allows the system to boot normally once energy is reconnected.
on Jan 10, 2010 | Computers & Internet
Dell dhp power button flashes will not turn on
Battery is Down
Adaptor not working
plug out the battery and keep it on AC power only
press the button to verify that the board receives power from your adaptor
if led does not blink this time then it is the adaptor otherwise it is the RAM not detected
Nov 28, 2013 | Computers & Internet
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
How do i reboot my acer aspire 5315 laptop and i have already tired the f10 trick and pressing alt and f8 not working how do i do it can someone help me please
Not sure what caused your issue but try thisL
Remove the battery and let your system sit about 30 min. (no battery or power adaptor) Before re-inserting battery/power, press the power button a few times (5 or 6) Reinsert battery and/or power adaptor and reboot your system. (Do not press any keys, just a normal boot.) If all goes well you should see a screen with "Windows shut down unexpectedlly, what would you like to do... or "press Fx to boot or Fx to enter setup")
Good Luck
C2Solutions
Jan 23, 2011 | Acer Aspire 5315 Notebook
My Lenovo s10 power adaptor (Input 1.7A, Output 20V 2A) was working just now together with the battery. After i didn't used the laptop for an hour and returned to switch it on, the power adaptor isn't...
hi,
You said laptop is working fine if just using the battery,that means that there is nothing wrong with the battery itself. Can yu please try to connect the laptop directly to the power outlet without using the battery just for the mean time,remove the battery and connect the AC adapter directly to the power outlet then power on the laptop,if nothing happens,that means that there is something wrong with the AC adapter itself or the power port on the laptop.
Hope this will help...
Jan 09, 2011 | Lenovo IdealPad S10 Laptop AC Power...
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
My officejet7210 all-in-one, not working . i shut it off to checjk all connections, i had to to move the printer, now it wont turn on. I've pushed the on button quickly, held it. no go. any ideas?
hi, lets try some reset on the printer but before that make sure that the printer is directly connected to the wall socket and there is no power surge protector connected now place your hand on the the power adaptor of the printer and check if the adaptor is heating or not if its heating then proceed further if not then there is some problem with the adaptor
now connect the power adaptor to the printer and then try turn on the printer if its not turning on then press and hold the power button for 10 sec and then remove the power cable from the printer now keep pressing teh power button and after 10 sec reinsert the power cable and then release the power button
still if the printer is not powering on then press the # and 3 button on the printer and then while pressing them remove the power button wait for 5 sec and then replug the cable while pressing the buttons
now try to power on the printer if not powering on still then try the above step using the # and 6 buttons if till face the problem then the device needs service
Aug 29, 2009 | HP Officejet 7210 All-In-One InkJet...
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
May 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Compaq Presario 1680 Notebook shows no power in window when plugged in.
Take the battery out disconnect the AC adaptor Press and hold the power button about 7 seconds. Put the battery in and connect to AC adaptor press and release the power button. If it caused by static-component lockup, issue will be resolved. If still there is no activity including no power light check the AC Adaptor if its working
Good Luck
Dec 30, 2007 | Computers & Internet
HP Deskjet D2360 InkJet Printer Logo
132 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
