Question about JVC KD-HDR1 CD Player
No bass in my car
I have the Jvc Kd- hdr1 cd player in my ford stang gt with the mach system. My question is the speakers are getting no bass at all(I have no subs). There is no beat to the speakers only treble. I have tried going through the sound staging and same problem presist. What can I do?
  • mustangfan Jun 14, 2008
    I have a Panasonic installed by BB about 3 mo. ago in my 2001 GT convertible with 460 Mach. My bass is gone and have read horror stories regarding speakers/wiring for the Mach and other head units. I am hoping guru is right and it's just blown.
  • 2,039 Answers
If it a 6x9 they is no miracle to it speaker blown cheers
Posted on Jan 14, 2008
Jvc kid hdr 20 power comes on manually, then goes off?
This is an internal problem if you state your power cables (RED YELLOW and BLACK) are secure.
Jul 16, 2014 | JVC KD-HDR1 CD Player
Installing JVC KD-R740BT in 1997 Ford truck, keep getting "miswiring, check wires and reset" message
Check speaker wires. All four speakers must be independent. Means no shorting to chassis.
Sep 25, 2013 | JVC KD-HDR1 CD Player
Jvc kd-hdr1
Most wiring now is standard to a switched power source...Yellow=battery...goes to a hot all the time(even with key off) front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - left rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
if there is an auxillary input on the radio you can plug it in through that, if not you need a fm transmitter to do it... you can pick em up at your local radioshack
Aug 09, 2011 | JVC KD-HDR1 CD Player
Looking for jvc car stero manual for KD-HDR1
Jul 09, 2011 | JVC KD-HDR1 CD Player
Hold the sel button, then release. use the right arrow to scroll through the options until you get to clock h.
Use the volume knob to change the hour.
Press the right arrow again to get clock m
Use the volume knob to change the minute.
Aug 31, 2008 | JVC KD-HDR1 CD Player
This radio can not use a common ground. If your speakers are all grounded together you will blow up the amp IC in the radio. The negative speaker wires run at about 6 or 7 volts and so do the positive speaker wires.
Trust me, run new speaker wires, do not common ground any of these speakers
If this was helpful a good rating would be appreciated.
Mar 08, 2008 | JVC KD-HDR1 CD Player
Only bass coming through speakers
Nevermind, the unit fixed itself... i dont know what happend...
Mar 07, 2008 | JVC Arsenal KD-AR3000 CD Player
CD player heats up
The reason the CD it is gettng hot is because of the amplifier IC in the radio. The CD player is right in front of the amp IC and it is all in an enclosed area with little ventilation. They do get hot after a while.
It is not unusual for a CD to get hot after playing for a while.
The JVC stereos are known for having a bad spindle motor. That can cause the problem you are describing. A bad laser pick up can also cause the same thing.
There is no way of knowing just what the cause of your problem is without having it tested by a technician.
The laser pick up is more prone to failure from heat if it is getting weak.
The spindle motor is a little more common problem with the JVC car CD players.
But I have repaired both of those problems in JVC CD players many times.
I work at a JVC authorized service center, Most of the JVC CD players use the exact same CD mech, whether it is a cheap unit or a more exspensive one.
The only user action that you can do is to run a cleaning disc thru it for about 20 to 30 seconds. But that is not going to change your problem, you need to have it checked out at a service center, but if it is not under warranty it may not be worth getting fixed. The repair can run from $70 to $125 depending on the rates of the service center.
If you need any more help or questions answered, feel free to ask. And if this was helpful to you a good rating would really be appreciated.
Oct 17, 2007 | JVC KD-HDR1 CD Player
JVC KD-HDR1; How to change the time?
No Manual with it? See if there is a download fron the JVC web site.
Jul 16, 2007 | JVC KD-HDR1 CD Player
JVC KD-HDR1 CD Player Logo
182 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
