Question about Microsoft Xbox 360 Console
Will not play 360 games
Ive got 1 red light on the lower left side and i can not play any x bo360 games dvd cd are ok if any 1 knows how to fix can you help asap
You have a bad laser. I have had the same problem with my XBOX 360. If your system is still under warranty you can send have Microsoft fix the problem for you. If not they will charge you $99.00 US dollars to fix it but will give you a new one year warranty. But if you are like me I went online and bought a new laser from ebay for about $15.00 and install it yourself. If you need more info let me know or you can go online and get all the info you need.
Posted on Jan 07, 2008
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
Jan 14, 2011 | Microsoft Xbox 360 Console
When we put in a game for our 360 system it says it's playing a dvd we can't get the game to work. how do i fix it so it says play game amd not play dvd? (it only does this with 1 game. the rest work fine
Ok if your for certain thats the original dvd drive and the other games work then its too many scratches on the disc or your laser lens needs wiped off with qtip and rubbing alcohol.
If you get an xbox thats say play dvd all the time on every game and it says to play this disc stick in a xbox 360 console then its the wrong dvd drive for that motherboard and you wont get the key (on a chip in the motherboard on the cd drive) unless you have the original dvd drive taken out of your xbox. Then you can just switch that little motherboard on the bottom of the dvd drives and it will read games. This is for those who will look at this with a xbox off ebay that they cant figure out how to fix. Its just an expensive dvd player.
Dec 26, 2010 | Microsoft Xbox 360 Console
My 360 will play movies all day long, but when I put a game in it plays for approximately 3 minutes and shuts off. The lights on the left side of the power button flash red. What is the deal?
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing.
you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove
Sep 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Xbox360 that doesn't know it is one
I had the same problem,If it is under warranty send it in ,,, if not then you are going to open it up,, plenty of instruction on how to do this online (google it). see what type of dvd drive you have and then go on ebay and purchase an identical replacment drive. once you recieve it open up YOUR ORIGINAL DVD DRIVE and unplug the green motherboard looking thing on top(Big ONE) there should be four little tabs on this. put it to the side . now open up the new dvd drive and repeat but make sure you dont get these cards switched up.put the old key in the new dvd drive , plug in all 4 tabs,bottom one first. put back together and install back into xbox360. put xbox 360 back together put in disk and enjoy
Sep 29, 2008 | Microsoft Xbox 360 Console
Xbox 360
Hey Jay- There is a plastic disc that sits on the centre of the drive inside the box, this disc has a magnet in it that is supposed to hold the game cd in place. What's happened is the plastic has become dislodged from the computer drive and is not the magnet portion is stuck to the drive housing (also metal).
You need to open up the game console, remove the drive and the drive cover and get that plastic disc out of it's holding plate. Once out, you just reinsert the drive (without the cover) and set the disc on top of the game cd-give the game a spin or two with your fingers and it should start up....problem fixed
If you search on Youtube you can see a repair video for this. It takes time, and you have to tear apart the game to get at this puppy. I've since fixed mine and left the plastic game housing off as well, so as to get rid of the overheating problem.
Screw microsoft and their crappy manufacturers.
Aug 16, 2008 | Microsoft Xbox 360 Console
Need help
i think you need to take it back, but if you get it back together get rid of all the data you dont need from your xbox it works. and the rings go away.
Aug 13, 2008 | Microsoft Xbox 360 Console
Xbox 360 wont play the games but will play cds and dvds !!!!
Mocrosoft only entended the warranty on the "ring of death" issue which was hardware related to overheating.  They did not extend the warranty to any other issues.  DVD/CD emulators and the games emulators are handled by different software.
You can try a factory reset of the console...
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the “Initial Setup” option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks
This might work only with older versions of Xbox 360 dashboard.
Press the following key combination
Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
If none of this works contact Microsoft and see if the console is still under warranty.  If not they will repair it for usually 99.00
Dec 28, 2007 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
