Computer 'Won't boot
Hi all. Not sure where I went wrong, I have an ASUS p4pe Black Pearl Motherboard with 2.0 GHZ processor. Up until a week ago it was working fine for 2+ years. Now, The motherboard shows green light when power supply is plugged in, the cpu fan spins immediiately when the power to the supply is turned on, but the computer will not attempt to boot whatsover. I have tried running with known working components and have run barebone but it will not attempt to boot up--- no hard drive spin, no warning beeps or anything. I'm not sure where to start. I even took all components out of case and ran like that with same results. I am using ATI AIW 7500 AGP card for the vid card. I'm not sure when the computer last worked as it is not one I use all the time. BEFORE all this happened i tried downgrading the vid card (I was having capture errors but that's a whole nother story) to a ATI 128 pro. The computer worked fine with that card, I updated drivers restarted and left the computer for a day or so (again not a computer i use a lot)When I came back to it is when this non booting problem began. I tried going back to the AIW vid card and even tried another card but to no avail? Where should I start? Any help is appreciated! Thank you!!!
  • Anonymous Mar 19, 2009
    my computer won't boot
  • Anonymous Mar 28, 2009
    My friend said his pc wouldnt startup either so i went round and it sounds like the same thing, i press the power button cpu and case fan starts but stops after a second. the green light is on on the motherboard, i have tried with a psu that works fine but it didnt solve anything.
Try replacing the CMOS battery
Posted on Aug 17, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
You did try the other card? obviously u did.
now remove every thing but PROCESSOR and RAM and forget about the Video remove all internal parts. then see that it beep or not.
a normal start up beep.
Posted on Jan 07, 2008
I realized I need an AGP to connect a monitor to my Asus P4PE-BP. Will AGP 8X work. Specs call for AGP 4X.
The 8x AGP cards will work in the 4x slot. But the 8x AGP card will lose about 1% to 2% of its performance.
Mar 31, 2014 | ASUS P4PE-BP Motherboard
Hi.. I have a server system having Intel Pentium 4 processor. The following details are written on the Processor. Intel (m) (c) '03 PENTIUM (R) 4 2.8 GHz, IM1800, jl79k MALAY, Q417A92 t417b040 ...
hi,
you can on this motherboard models for your intel Pentium 4 processor,
1. ASUS P4P800 Deluxe
2.MSI Neo2-FIS2R
3.ASUS P4C800 Deluxe
4.Intel D865PERL
5. ABIT IS7
Feb 16, 2011 | ASUS Support Intel Pentium M Processor and...
Looking sound driver installer to my computer asus p4pe acpi bios revision 1005
Go to asus.com and enter your info there. You will be shown a page with all the pertinent drivers for your computer. Download your audio driver and then install it. If you still don't have any audio after that then your integrated sound card may be burned out. You can easily fix that by getting a PCI sound card.
Mar 19, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
Earlier i had ASUS P5G-MX motherboard & 2.0 GHz Core 2 duo Processor.I upgrade my Motherboard to Asus P5KL-AM/PS & then i have a black screen with my 2.0 ghz processor, But i tried 2.8 ghz Core 2...
HI,
The only Thing To Do, is view both Motherboards, user Manuals.
To see The boards CPU Support List.
It could be to do with, certain Motherboards Supporting, certain CPUs.
I.e a 533mhz cpu, would not run on a Motherboard that supports 400mhz. The Systems Bios, May cause Other Problems.
If your getting a Black Screen, is it a possible Graphics/Ram Problem, Rather Than The CPU ??
Mike @ Compurepair.
Oct 22, 2009 | Intel Computers & Internet
What does one long beep mean on asus p4pe
i'm guessing starting up?
possible
Processor issue
Ram issue
Hdd missing or corrupted
keyboard missing or incompatible
Mouse missing or incompatible
Fried *insert computer part here*
and so on and so forth
Sep 27, 2009 | ASUS P4PE-X Motherboard
PC Not booting up
HI
Please change the smps your cpu and check it..
i'm sure it will work..
Nov 19, 2008 | Computers & Internet
P4PE Motherboard system hangs on 2 memory banks
you need to check in your bios settings for the amt of physical memory setting. alsoexamin the board for defect. if all that is good then follow the following instructions
1.)Unplug computer
2.)remove memory
3.)switch jp1 to clear ( the jumpewr that clears the bios is called jp1 its located close to the battery and it has 3 pins and 1 jmper) the pin set will be on 1 and 2 , simply set it to 2 and 3)
4.) Hit the power button 5 times to clear all remains of eletricity
5.) REPLACE JUMPER TO 1 AND 2
6.) replace memory
7.) boot up system
8.) on the main boot screel it should say no bios settings enter setup
9.) enter setup and load optimal defaults
10.) save and exit
Dec 31, 2007 | ASUS P4PE-X Motherboard
Computers & Internet Logo
1,082 people viewed this question
David Payne
David Payne
