Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed?The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
It has nothing to do with the tight fit. It has everything to do with self-cleaning on ovens. The thermal fuse blows due to extreme temperatures. Replace the fuse to use the oven. Use an oven cleaner to clean the oven OR replace more fuses in the future.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
you can try and hold the door closed by hand and push the self cleaning button.and it might work
if that does nothing for you there might be a problem with the door switch.
the other likely problem is a bad clock timer/main control panel
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $$$$
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following: [email protected]
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
big dib, the TC0, ( thermal cut out) probably has opened. This is non resetable. To get at it you have to pull the oven out to a point where you can get at the back. Then you have to remove the oven back panel and there is the TCO. Part number 4450249. You can verify this by ohming out the TC0, if it shows open (no continuity) it's bad. I have done a number of these and it takes two people to repair it safely. Kill the breaker when going in there. Catriver..post back.
