Question about Sony Handycam CCD-TRV318 Camcorder
Dispays End Of Tape/Eject symbol
Unit displays End Of Tape / Eject Tape symbols in yellow only when in Camera mode. If I put unit into Player mode I can put any tape in and all functions operate normally. However as soon as I flip it to Camera mode I hear three quick beeps and this message comes up. I have a copy of the service maual and went into diagnostic mode. It has never had any other problems and the diagnostic has no error codes in it's history log. I have tried many tapes and I don't know why it stopped working. I keep the unit in a foam lined Pelican 1400 case with moisture absorbing beads and all to protect my equipment. It has never been dropped dinged or scratched. It looks like new and is only about 4 years old.
  • 1 more comment
  • william123 Jan 20, 2008
    when i try to record or play back my videos a loud beeping sound occurs and a yellow symbol of a tape pops up on the screen telling me to either eject it or theres no tape at all.
  • Anonymous May 12, 2008
    i have the same prob how to i fix it
  • ali_bacha88 Sep 26, 2008
    Genius:
  • Sony Master
  • 1,689 Answers
The tape end sensor, or record sensor has a fault, or the electronics that reads the sensors has a fault. This could be dirt on them, or an actual failure of some type. Without dissassembly and proper troubleshooting, speculation would only be a guess.
The service diagnostics do not show every possible type of failure that can occur in the camera. It only shows the main areas.
Jerry G.
Posted on May 02, 2008
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Have SANYO VCR/DVD Model E175216 and can't locate timer button for late night programming
Hi, if ithere is no button on the front of the unit or on the remote, then simply setting the unit to standby with either power button should make the unit enter the timer record mode. (This will be indicated with TIMER or a small red clock symbol in the display providing all the conditions have ben met. i..e clock & timer correctly set, tape in machine, etc)
Mar 16, 2010 | Sanyo DVW-5000 DVD Player/VCR
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
Cannot record or play
The C31:22 message indicates that one of the motors inside has failed to turn. This is a safety message and the unit will eject the tape to prevent the tape from getting damaged. Unfortunately, there is little that you can do other than get the unit into a service shop. The repair of this will require dis-assembly of the unit. I would suggest that you either get an estimate for the repair or send the unit to Sony using one of their fixed rate repair options.
Dan
Sep 26, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Player shows ejects symbol and shuts off after about 45 seconds
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
Jun 13, 2008 | Sony SLV-D251P DVD/CD Player w/Built-in...
Vcr eject manfunction.
Sound like you have to open your VCR and help it left up to eject. I had the same problem.
Mar 14, 2008 | Philips Magnavox Learning Universal Remote
Tape/Display problem
Straight from the manual:
C:21:ss Moisture condensation has occurred.
-> Remove the cassette and leave your camcorder for at least one hour to acclimatize (p. 291).
Mar 12, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Insignia portable CD player model # NS-P3112
Look everywhere on the unit for a button that says hold or lock. Its usually on the side near the 'eject' or 'volume' buttons. Good luck!
Dec 24, 2007 | Insignia Sport lDM9700-2 Personal CD...
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony Handycam CCD-TRV318 Camcorder Logo
218 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
