Question about Konica Minolta magicolor 2430 DL Laser Printer
Toner is skipping in same part of the page
An area about 1/8th inch to 1/4 inch either doesn't pring or is very light. It goes the entire length of the page. All of the cartridges have just been replaced so that isn't the problem I don't think. Same problem as everyone else seems to be having. Lighter color streak about 1/4" wide running from top to bottom on the left side of the page. Have just printed 100's of jpegs and most pages have these flaws. Have cleaned lens, cartridge is still newish and am not out of any of the toners. Adjusting the pages to avoid the bad sector makes the pictures look all crowded to the right of the page. ARGH !!!
    Genius:
  • 1,003 Answers
You have a weak photo drum or dirty corona wire take drum assy out and spray metal grid above drum suface with canned air until free of toner dust(take outside to prevent toner dust from getting on carpet or household ) items.
After cleaning reinstall drum and run printer.
Posted on Jan 07, 2008
Hp g20 touchpad skips
Reinstall drivers. Did you droped your lappy recently ? Have it checked in service !
Nov 04, 2012 | HP Computers & Internet
Black lines going straight across paper. 1 every inch down
If the streaks are narrow black and run the entire length of the page, replace the soft plastic wiper blade on the drum (and hope the drum is not scratched). Black smudges are related to the toner/developer purity. Replace both.
Jul 06, 2011 | Canon PC981 Copier
Hp 4300 laserjet. All printouts have a blank space
Remove the toner and wipe the small window that's above where the drum unit sits inside. That window gets covered with toner and makes light prints and blank areas.
Nov 18, 2009 | Office Equipment & Supplies
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Skipped Print Areas on Printouts
You may have a bad toner cartridge, if the cartridge has contaminants in it, it will not put toner on the drum in these areas, Try removing and giving the cartridge a good shake, try installing a new or at least another cartridge to see if the problem is here.
Hope this is of some help.
Ed
Apr 30, 2009 | Office Equipment & Supplies
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
Copy star 3035
The drum unit may need to have the toner collection blade replaced. not the cleaning blade for the drum but the one below it that catches the toner cleaned off the drum. if this blade is old or damaged it losses its seal to the drum and drops tiny specks of toner onto the page.
Hope this helps...
Lbcoast
Aug 20, 2008 | Copystar CS-2030 Copier
You may simply have some toner dust on the laser lens cover. Take out the bit with the green handle and look inside. There's a glass piece about 4 inches (100 mms) by 1/2 inch (12mm) which easily gets dirty. Carefully wipe with a clean soft cloth.
Probably you got some toner dropping on it when you removed the old cartridges.
Mar 27, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
122 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
