Question about SanDisk Sansa e260 MP3 Player
Oo buck time!
Ok newE-260. WMP 11 can not get wmp 10 to load. Recorded a bunch of brand new cd's, tried Rhapsody, then Drag and drop, then winamp, Yahoo music box. MC mtp whadda F__is that crap. Treid both ways. Funny some willbe there and if shuufle I get the box but it goes away and the music plays. Next song is usually from same artist.
Someone got an easy fix to prevent THE DREADED RED BOX with BAD TRACK in it.
I am going back to WMP 9 unless you gurus out there have A fix that works.
Thanks Plenty.....Blackops0321
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
How do I load my music cd's into my computer then download them to my new polaroid MP3 player
Windows media player will do it automatically.
If not :
Place a cd into the try and close it.
Open WMP.
Open the CD in WMP.
Select all songs, and click the RIP tab.
They should, by default, go to "My Music" folder in a folder named after the CD your ripping.
When you attach your MP3 player,
Autorun will ask what do you want to do?
say open a folder to view files, or let WMP sync up to it.
You can manually drag and drop your files to the MP3 player.
PLEASE RATE THIS ANSWER.
Aug 30, 2011 | Audio Players & Recorders
Cant get any of my wmp 11 music to download to it
You can use the easyRip software's Player Loader module to easily put music on the device. Otherwise, you can always drag and drop media using Windows Explorer or use the WMP Sync option (may require the device to be in MTP mode)
Nov 11, 2009 | Audio Players & Recorders
Sansa e260 mp3 player came with no software cd
There is no Software Needed for this Player. It is Designed to "SYNC" with Windows Media Player. If you have got the latest WMP you will be OK, If Not, Download the New WMP. When you Start WMP on the Tabs at the Top, One of them will say Sync. Just Click and Drag your Songs to the Pane on the Right. When you are Ready Press Sync at the Bottom and it will Put them on your Player.
Jan 11, 2009 | SanDisk Sansa e260 MP3 Player
Gtalk not showing my current album status... :-(
gtalk is fully compatible with wmp 11.
if it stops showing the current track,
open wmp,
right click on the bottom pane,
goto tools-pluggins-options.
select background,
check gtalk.
that should solve ur prob.
Dec 17, 2008 | Google Talk
I dont have a disk or manuel for my sandisk sansa m240 how can i download music to it? I have the usb cord tho.
Follow these steps to drag-and-drop music files to your Sansa player:
1. Connect your Sansa player to your computer.
2. Open Windows Explorer.
3. Double-click on your Sansa player.
4. Double-click Internal Memory if you are using WMP 11 or double-click
Media if you are using WMP 10.
5. Drag and drop music files from your computer to the Sansa player’s MUSIC
folder.
Dec 10, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
Album art
u can use the other mode to put the album art on it too....
just drag and drop the album art using wmp 11...
if that doesn't work the slow way is to use iriver plus 3 and add it manually.
i suggest organising your files by placing albums into individual folders with their album art...
u can also use other programs like itunes or winamp to add album art...
Apr 26, 2008 | iRiver X20 MP3 Player
Possible Incompatibility with WMP 11: Deleting Recorded Files
Its Nothing YouCan Do I Tried Everything...This MP3Was Set Up For The Older Version Of WMP Because At Work I Have WMP 10 And It Works But A Home I Got WMP 11 And It Doesnt Work...Its Just Something To Kee You Coming Back TO Buy Their Items
Dec 08, 2007 | Samsung Yepp YP-T7JX MP3 Player
Please help me!!! im desperate!!! sandisk sansa e260
if your sanas e260 does'n syncronize with your computer or say data base..., take the battery out and conect it with out the battery.
May 08, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
