Question about CTX P772 17" LCD Monitor
FIXING OF MONITOR CABLE
THE MALE PLUG ON THE CABLE THAT LEADS TO THE DISPLAY OF THE COMPUTER CAME LOSE. WHAT IS THE CORRECT WIRE COLOUR CODE AS THERE ARE 7 DIFFERENT COLOURS . CAN YOU PLEASE HELP.
SCREEN SANSUI MODEL 1770 AND PRODUCT CODE MON-17B
THANKS.
    Scholar:
  • 87 Answers
Should be a female plug. There should be 15 pins. Not all are used though. You best bet is to open the monitor and see if they tagged the main board with the letter codes of the wires. If they did use http://pinouts.ru/VideoCables/9to15VGA_pinout.shtml as a guide
Hope this helps
Posted on Dec 05, 2008
  • 981 Answers
Heh, it's not all that consistent. If it fits, plug it in and try it without fear of doing harm; if you had described the end of the cable (e.g. what type of connector it was, 1/8" stereo jack, SVGA or DVI) it would clear things up a bit, but then it would also be obvious where you could plug it in. Center or Forward Stereo Out will probably do nicely if it's that 1/8" diameter stereo jack (not that it makes that an optimal audio solution, but I don't know you keep spare 7.1 mixer/amps and speakers around.)
Posted on May 12, 2008
Monitor display flickers a lot and colours change
If the monitor is external, make sure the connecting cable is in properly. If it is a vga cable, ensure it is screwed in tight, not just plugged in. If the display is built it, I suggest you take it to your nearest computer repair shop for them to have a look at it unless you have previous experience in this or a really tech savvy family member/friend.
Oct 19, 2012 | Packard Bell Computers & Internet
Install external monitor from desktop to laptop
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
http://www.cablewholesale.com/specs/dvi-to-vga-cable/30dv-05300.htm
Below is a picture of what it looks like.
Jun 03, 2012 | Dell Computers & Internet
How to install external monitor to laptop if laptop does not support 15 pin plug from monitor
Jun 03, 2012 | Dell OptiPlex 780 Desktop Computer 1 x...
I connected my mag monitor to my emachines pc im trying to make the speakers work on the monitor so far no luck ////??? the monitor is a mag lt782s and the pc is a emachines t6410
You should have been provided with an audio cable when you purchased the monitor, it is a standard male to male 3.5mm cable, possibly with green ends on it. One end will plug into the monitor, the other will plug into the speaker port on your computer, usually colour coded green
hope this was helpful.
May 30, 2011 | Computers & Internet
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Connecting laptop to tv
1. If your tv has a PC input, use a vga cable, from any normal computer monitor.
2. If you use those HD connectors, match them to the correct colour coded inputs on the tv.
In each case, do all the connecting with the computer POWERED OFF. Then when connected, boot the computer, and allow Windows to auto-detect the 'new monitor', as it will 'see' it.
Then you shoud right click on your desktop, choose properties, and goto 'settings'. From there you will see monitors 1 and 2. click on the new monitor and 'enable' it.
You also have the option of 'extending' windows to the second monitor, as well as making this your 'default monitor'. Experiment to see what best suits your needs,
Erik.
May 16, 2008 | Dell Precision M60 Notebook
Dvd hook up
Depending on what leads you have and what connections your equipment has depends on how you would wire it up for a basic setup you need a set of three male to male rca a leads consisting of a RED WHITE and Yellow plugs at each end. Now on the back of your dvd player there should be three female holes the same colou as your plugs and near those holes it should say input plug the leads colour to colour now the other ends of the lead plug into the section of your amp thats says dvd input with the same style holes as the dvd player. then you need to run another cable the same as you have just used to take the sound and picture to the tv you start of plugging one end into the amp where it says monitor or tv out and then at the other end of the lead will plug into the tv in A/V1 or A/V2 if the A/V1 is being used for a video player or camcorder Yellow is Picture Red is Right Sound Channel And White is Left Sound Channel so only plud the matching colours to each other or you will end up no better off hopefully this helped if you get stuck my email is warneatbribie@hotmail.com
Mar 23, 2008 | Pioneer VSX-108
CTX P772 17" LCD Monitor Logo
82 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
