I have a RCA D52W19 52in Rear Projection HDTV and my tv green light flicker on and off 3 times... No sound.. No picture. As I am reading the other responds I noticed all of these tvs' seem to be on a timer. They all seem to be going out at the same time. RCA TV seem to be no good!
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
My D52W20 will power up for a few seconds and then shut down completely. It will not power back up...
(More)
My D52W20 will power up for a few seconds and then shut down completely. It will not power back up until ac input is cycled. You can hear what sounds like the high voltage energize when it is turned.
my RCA rear projection(model#p52936) stopped working i tried to turn it on and it sounds like a high...
(More)
my RCA rear projection(model#p52936) stopped working i tried to turn it on and it sounds like a high pitched squeek. no picture
