Question about Dell Dimension 8400 PC Desktop
Slow burner i have a dell dimension 8400 and use 16x dvds but the burner only burn at 3.8 x wath can i do
  • 2 more comments
  • andrewyeva Jan 07, 2008
    my burner is a philips dvd+rw dvd8801
  • andrewyeva Jan 08, 2008
    ok thanks but checking in the dell page inotice tha there is no drivers for that burner in the xp section only in the vista section . that can be a problem?
  • Anonymous Mar 18, 2009
    I'm having the same problem with slow R/W's with the 8801 using fw 4D28 and WinXP.
    Tried 2 different PC's Dell GX620 and GX240.
    I know it's the drive (other drives OK) so I suspect the firmware.
    Bob
    Genius:
  • 1,226 Answers
Install the driver of your DVD burner, Use nero burner and compatible BLAnk DVD Discs.
Posted on Jan 07, 2008
  • Emelio Navaja
    Emelio Navaja Jan 07, 2008
    set the burning speed to maximum or depending on the speed you desired.
  • 2,427 Answers
Well what you can try is
1.) Cleaning your registery out
2.) deleting all temp files
3.) defragmenting your registery
to do all the above you can use a product know as tune up utilities aviable here www.phazeddl,com type yune up in the search box and search it
4.) defragmenting your harddrive
to to this go into my computer
right click on local disc and click properties.
clicl tools the defrag
5 delete your preftech files
they are located in c:\windows\prefetch
6 empty your recycle bin
7 restart
ensure you have 16x media and your burningspeed is set to 16x
4x media means you can only burn at 4 8x at 8 or below, 16x at 16 or below
if all fails then you need to format and reinstall
dont forget to rate me
  • Rishi Roshan Ali Jan 08, 2008
    Xp uses a generic driver for all burners,, if there is a problem with the driver it means there is a problem with your xp instillation it self, you will need to format and reinstall
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
Dvd wont burn dvds
It could be an issue with the software or hardware.try and burn with windows utility.if it fails then try deleting the upper filter and lower filters from registry.reboot.try and burn again if it doesn't work then it could be an issue with the dvd burner drive.
Mar 14, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can i burn dvds on my 2350 dell dimension computer if not what do i need
well if u have a dvd burner or a dvd writer installed on ur computer
then u will need to install softwares like NERO or ROXIO on ur computer
first chk, i thnk it mite be already installed on ur computer.
use them and u will be able to burn DVD's
Nov 02, 2009 | Dell Dimension 2350 PC Desktop
Dvd burner drive E:\
Are you absoulutely positive that yours is a dvd burner as well as a cd player?? Not being a wise guy, I am serious, sometimes it can be something simple...Steve
Jun 13, 2009 | Dell (M6790) DVD RW Burner
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dvd burner not detected
Sorry, but that model is not a DVD writer. It can only write and rewrite CD's. It can only read DVD's.
Here is a page with specs:
Sony CRX310S Specs
Note under DVD>Write DVD it says N/A. (Not applicable.)
Mar 23, 2009 | Dell Dimension E521 PC Desktop
Do I need a special burner to record on DL DVDs?
yes you do, you need a Dual layer DVD burner, not every DVD burner does burn DL DVDs.
please rate if you can
Feb 13, 2009 | Dell Dimension 8300 PC Desktop
Cd/dvd burner too slow
It may just be that that is the speed of your drive.  See if it says on the drive how fast it is.  If it is too slow, then you may want to consider getting a newer, faster drive.
Feb 03, 2009 | Dell Dimension 3100 PC Desktop
CD BURNER
Are you using a Rewritable CD? When they're new, they're really fast, and they slow down the more you use them.
Mar 20, 2008 | Dell Dimension 3000 PC Desktop
Dvd-rw drive not working
Hi Elaine, Usually DVD recording issue can be related to the configuration or Hardware itself. please check if standard CD/DVD recording option is active you can see it by right click on CD/DVD drive and properties. Please check the box highlighted below
If it doesn't work you can contact to DELL hotline or alternately you can post the outcome on here
Good Luck
Feb 07, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 8400 PC Desktop Logo
76 people viewed this question
Alun Cox
